Form Factor |
Book-size Mini-ITX chassis |
Construction |
Heavy-Duty steel |
Mini-ITX Board |
Support:
LV-675: Intel Pentium M / Celeron M
LV-668 : AMD Geode NX
LV-667: VIA C3 / Eden
LV-660: VIA C3 / Eden
LV-603: Intel Pentium III / VIA C3 |
Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 3.5" HDD Space |
Riser card |
1 slots PCI riser card |
Thermal Control |
Two 4cm Ball cooling fan on rear side |
Front Panel |
System Reset switch
Power On/Off and HDD activity |
Rear Side I/O |
Depend on Mini-ITX''s I/O Plate |
Environment |
Operating Temperature: 0 ~ 50C |
Power supply |
80W adapter (12V/6.67A) |
Dimension |
270 x 295 x 63 mm |
Weight |
2.09 kgw , (Without board, HDD, CD-ROM) |
