| Form Factor |
2U height Mini-ITX chassis |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Support:
LV-671: Intel Pentium M / Celeron M
LV-670: Intel Pentium 4 / Celeron
LV-670M : Intel Pentium 4-M
LV-667: VIA C3 / Eden
LV-660: VIA C3 / Eden
LV-603: Intel Pentium III / VIA C3 |
| Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 3.5" HDD Space |
| Riser card |
2 slots PCI riser card
(660/603 only support one PCI slot) |
| Thermal Control |
One 4cm Ball cooling fan on rear side |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
USB Port x 1 |
| Rear Side I/O |
Depend on Mini-ITX''s I/O Plate |
| Environment |
Operating Temperature: 0 ~ 50C
Altitude: 3,000m
Vibration: 1.5G Max acceleration |
| Power supply |
180W ATX Power Supply
Input Voltage: 100 ~ 240 VAC full range |
| Dimension |
335 x 230 x 88 mm (W x H x D) |
| Weight |
N.W. 5.5kgw , (Without board, HDD, CD-ROM) |
