| Form Factor |
Mini-ITX barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Inside Motherboatd can be :
LV-674 : Intel Pentium D / Pentium 4 / Celeron D
LV-672 : Intel Pentium 4 / Celeron
LV-677 : Intel Core Duo / Core Solo |
| Drive Bay |
External 1 x Slim CD-ROM & 1 x Slim FDD Space
Internal 2 x 3.5" HDD Space |
| Riser card |
1 x PCI-Express riser card |
| Thermal Control |
One 12 cm system cooling Fan |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
2 x USB ports |
| Rear Side I/O |
Depend on Mini-ITX I/O plate . |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
300W ATX power supply |
| Dimension |
305 x 284 x 119 mm |
| Weight |
5.65 kgw , (With Case , Motherboard , power supply |
