²úÆ·Ãû³Æ£º
CMB-671CM6
ÐÍ ºÅ£º
CMB-671CM6
̨Íå¿Ïí®(COMMELL)
| Form Factor |
Mini-ITX barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Inside Motherboatd can be :
LV-671MPCM6: Onboard Intel Celeron M 600 MHz CPU . |
| Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 2.5" HDD Space |
| Riser card |
One PCI riser card |
| Thermal Control |
One system cooling |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
4 x USB ports
Audio ports
CompaactFlash socket |
| Rear Side I/O |
PS/2 Keyboard and mouse, VGA, parallel port ,Dual USB,LAN,PCMCIA,5-1CHs Audio,2 x COM ,SPDIF |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
80W adapter |
| Dimension |
178 x 180 x 87 mm |
| Weight |
2.89 kgw , (Without motherboard , HDD, CD-ROM) |
