²úÆ·Ãû³Æ£º
CMB-670
ÐÍ ºÅ£º
CMB-670
̨Íå¿Ïí®(COMMELL)
| Form Factor |
Mini-ITX barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Inside Motherboatd can be :
LV-670: Intel Pentium 4 / Celeron |
| Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 3.5" HDD Space |
| Riser card |
No |
| Thermal Control |
Two system cooling |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
2 x USB ports
Audio ports |
| Rear Side I/O |
PS/2 Keyboard and mouse, TV-out, parallel port ,Dual USB,LAN,IEE1394,5.1 CH Audio,1 x COM |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
120W adapter |
| Dimension |
260 x 178 x 88 mm |
| Weight |
3.4 kgw , (Without , HDD, CD-ROM) |
