²úÆ·Ãû³Æ£º
CMB-564
ÐÍ ºÅ£º
CMB-564
̨Íå¿Ïí®(COMMELL)
| Form Factor |
5.25" Barebone |
| Construction |
Heavy-duty Steel |
| Mini-ITX Board |
Inside Motherboard can be :
LE-564E5R-128 : Onboard VIA Eden 533 MHz
LE-564E5G-128 : Onboard VIA Eden 533 MHz |
| Drive Bay |
Internal 1 x CompactFalsh Card Space |
| Riser card |
No |
| Thermal Control |
No |
| Front Panel |
Power On/Off and HDD activity LED
4 x LED for LAN status |
| Rear Side I/O |
4 x RJ45 LAN , 1 x DC input , 1 x COM , 2 x USB , 1 x VGA |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
DC 5V input |
| Dimension |
210 x 48 x 152 mm (W x H x D) |
| Weight |
1.01 kgw , (With Case , Motherboard ) |
