²úÆ·Ãû³Æ£º
CMB-363
ÐÍ ºÅ£º
CMB-363
̨Íå¿Ïí®(COMMELL)
| Form Factor |
Mini barebone system |
| Construction |
Heavy-Duty steel |
| 3.5" Mini-board |
Inside Motherboard can be :
LE-363 : Onboard AMD GX533 processor |
| Drive Bay |
Internal 1 x 2.5" HDD Space |
| Riser card |
No |
| Thermal Control |
No |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
2 x USB ports , Line-in / Line-Out / Mic-in |
| Rear Side I/O |
DC input, PS/2, 2 x LAN ports, DB15 VGA, COM, CompactFlash,
PCMCIA |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
DC 12V input |
| Dimension |
164 x 127 x 50 mm |
| Weight |
0.74 kgw , (With Case , Motherboard , 2.5 HDD) |
