²úÆ·Ãû³Æ£º
CMB-362
ÐÍ ºÅ£º
CMB-362
̨Íå¿Ïí®(COMMELL)
| Form Factor |
Mini barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Inside Motherboatd can be :
LE-362 : 3.5" MB with onabord VIA Eden 667 MHz . |
| Drive Bay |
Internal 1 x 2.5" HDD Space |
| Riser card |
No |
| Thermal Control |
One system cooling |
| Front Panel |
System Reset switch
Power On/Off and HDD activity
2 x USB ports |
| Rear Side I/O |
PS/2 Keyboard and mouse, TV-out / S-Video, parallel port , LAN, AC97 Audio,1 x COM |
| Environment |
Operating Temperature: 0 ~ 50C |
| Power supply |
80W adapter |
| Dimension |
235 x 135 x 58 mm |
| Weight |
4.58 kgw , (With Case and mothewrboard) |
