CPU: Intel Core 2 Quad processor in an LGA775 socket with a 1066 or 800 MHz system bus, Intel Core 2 Duo processor in an LGA775 socket with an 1333, 1066 or 800 MHz system bus, Intel Pentium dual-core processor in an LGA775 socket with an 800 MHz system bus, Intel Celeron processor in an LGA775 socket with an 800 MHz system bus.
Memory: 2 x DDR2 667/800 MHz DIMM up to 4.0GB.
Chipset: Intel Q35 Express Chipset.
VGA Interface: Intel integrated extreme GMA 3100 Technology.
LAN Interface: 2 x Intel 82573 Giga LAN.
Audio: Integrated ICH9DO with Realtek ALC888 HD Audio.
Serial ATA: Support 6 x SATA up to 3Gb/s.
I/O Ports: 1 x RS232 and 1 x RS232/422/485 Serial Ports, 8 x USB2.0 ports, 1 x DB15 VGA port, 1 x PS/2 keyboard and mouse ports, 1 x SPDIF connector, 1 x slim FDD port.
Extended Interface: One PCI Express x 16 bus add-in card connector, one Mini-PCI bus add-in card connector.
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
WatchDog Timer: 256-level generates system reset programmable watchdog timer.
Power Requirement: Standard 24-pin ATX power supply and P4 4-pin 12V.
