Form Factor: 170 x 170 mm CPU: support AMD Mobile Turion 64 X2 / Sempro processor at 638-pin Chipset: ATI RS690E & ATI SB600 Memory: 2 x 200-pin DDRII 533/667 MHz SO-DIMM socket supports up to 4.0 GB VGA Interface: built-in ATI RADEON X-1250 based 2D/3D graphics engine LVDS Interface: Onboard 24-bit dual channel LVDS Enhanced IDE: One 44-pin UDMA 33 IDE channel up to 2 ATAPI devices. Expansive Slots: 1 x PCI slot and 1 x Mini-PCI socket Serial ATA interface: 2 x SATA 2 interface with 300 MB/s transfer rate LAN Interface: 2 x Realtek RTL8111B Giga LAN Audio: Realtek ALC655 Codec External I/O Ports: 1 x RS232 & 1 RS232/422/485, 1 x PS/2 keyboard/Mouse, 4 x USB 2.0, 1 x Audio, 2 x RJ45 LAN ports, 1 x DB15 VGA, 1 x 4-pin DC input connector Internal I/O Ports: 2 x serial port, 1 x GPIO, 4 x USB 2.0, 1 x LVDS, 1 x DVI, 1 x 1394 Power Supply: Standard 20-pin ATX power supply or
