²úÆ·Ãû³Æ£º
CMB-679
ÐÍ ºÅ£º
CMB-679
̨Íå¿Ïí®(COMMELL)
| Form Factor |
Mini-ITX barebone system |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Inside Motherboard can be :
LV-679D :Intel® CoreTM 2 Duo (Merom) processor @ 800 MHz FSB
LV-679D2C :Intel® CoreTM 2 Duo (Merom) processor @ 800 MHz FSB |
| Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 2.5" HDD space |
| Extensive slot |
One for Mini-PCI, another one for secondary Mini-PCI or 32-bit PCI card |
| Thermal Control |
One 6 cm system cooling Fan |
| Front Panel |
Power on
System Reset switch
Power On/Off and HDD activity
2 x USB ports
Mic-in / Ear phone |
| Rear Side I/O |
PS/2 Keyboard and mouse, 4 x USB, 2 x RJ45 LAN, 2 x IEEE 1394, 1 x VGA, 2 x COM, 7.1 ch Audio , SPDIF, 1 x DVI. (CMB-679D2C with secondary DVI output connector and CF socket in solder side ) . |
| Environment |
Operating Temperature: 0 ~ 50ºC |
| Power supply |
12V/ 80W adapter |
| Dimension |
198 x 187 x 100 mm |
| Weight |
1.31 kgw , (Without HDD, CD-ROM) |
