Form Factor |
5.25" SBC (203 x 146 mm) |
Processor |
Intel® CoreTM 2 Quad / CoreTM 2 Duo Desktop
LGA775 800/1066/1333 MHz FSB. |
Memory |
2 x DDR2 667/800 MHz support up to 4.0 GB |
Chipset |
Intel® Q35 Express Chipset & ICH9DO |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1Min/Sec ~ 255 Min/Sec |
Power Management |
ACPI 1.0 compliant, supports power saving mode ATX PSU |
VGA Interface |
Intel® Q35 integrated GMA 3100 Technology |
| DVI or LVDS Interface |
Dual DVI or single LVDS interface |
Video Memory |
Up to 384MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA II Interface with 300MB/s transfer rate Support RAID 0,1,5,10 function |
Audio Interface |
Intel® ICH9DO integrated with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82573L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI slot & 1 x Min-PCI socket |
I/O Port |
2 x RJ45 LAN ports , 1x DB15 VGA port , 1x PS/2 Keyboard / Mouse ports , 1 x RS232/422/485 & 5 x RS232 Serial ports , 8 x USB 2.0 ports , 1 x IrDA , HD Audio ports , 1 x SMBUS
DVI or LVDS interface , 1 x LPT , 1 x slim FDD , 1 x GPIO |
Power Requirement |
Standard 24-pin ATX power supply and P4 4-pin 12V . ( 20-pin is compatible) |
Board Dimension |
203mm x 146 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
