Form Factor: 3.5" SBC ( 146 x 101 mm )
CPU: Embedded AMD Geode LX800 Processor .
Memory: One 200-pin SO-DIMM socket supports up to 1GB DDR SDRAM.
Chipset : AMD LX800 & CS5536
Real Time Clock: Chipset integrated RTC with onboard lithium battery
Watchdog Timer: Generates a system reset with internal timer for 1 ~ 255 sec (min)
VGA Interface: AMD Geode LX800 built-in high performance 2D Graphic , Supports CRT & 18-bit single channel LVDS LCD
PCI Enhanced IDE: One 44-pin IDE interface supports up to 2 ATAPI devices
Solid State Disk: IDE supports 44-Pin Disk On Module with +5V power supply, One Compact Flash Type II
Audio Interface: Realtek ALC203 AC97 Audio.
LAN Interface: 1 x Realtek RTL8110S Gigabit Ethernet controller.
GPIO interface: Onboard programmable 8-bit Digital I/O interface
Extended Interface: 1 x Mini-PCI socket.
Internal I/O Port :1 x RS232, 1 x GPIO, 1 x sile FDD, 1 x 18-bit single LVDS, 1 x DC IN, 2 x USB2.0
External I/O Port: 1 x PS2 key/mouse, 1 x COM, 1 x CRT, 1 x RJ45, 2 x USB2.0, 1 x DC IN
Power Requirement: DC 12V input .
Dimension : 146mm x 101mm
Temperature : Operating within 0~60¡æ ,Storage within -20~85¡æ
