²úÆ·Ãû³Æ£º
SP-320
ÐÍ ºÅ£º
SP-320
̨Íå¿Ïí®(COMMELL)
| CPU |
Samaung S3C2440,400MHz |
| Video |
Display |
3.5¡±Color LCD |
| Resolution |
320 ¡Á 240, 65k colors, Landscape |
| Memory |
32MB Flash |
64MB SDRAM |
| CPU Module |
SirF StarIII |
| Antenna |
Flip type |
| I/O |
Touchscreen |
Yes |
| Input Method |
Stylus pen |
| Speaker |
Build-in Loudspeaker * 1 |
| Headphone |
3.5mm jack * 1 |
| SD/MMC |
For SD and MMC Cards |
| TMC |
2.5mm earphone jack |
| Buttons & Switches |
Power key |
Power On/Off |
System Reset button |
Volume up,down(+ - Key) |
| Battery |
Type |
Rechargeable Lithium-lon battery, 1350 mAh |
| AC & DC Adapter |
Input |
100~240V AC |
| Output |
5V DC,1A |
| Car Charger |
Input |
12~24V |
| Output |
5V,1A |
| Certification & Regulation |
FCC, CE |
| Environment Conditions |
Temperature |
Operation: 0~40 ¡æ |
| Storage: 0~60 ¡æ |
| Humidity |
Operation: 0-90%,Non-condense |
| Storage: 0-90%,Non-condense |
| Size |
3.97¡± x 3.14¡±x 0.77¡±(101mm x 80mm x 19.6mm) |
| Weight |
202g |
