| Model Name |
CMS-675S |
CMS-675E |
CMS-675Q |
| Video system |
Video Standard |
Composite for NTSC / PAL |
| Video Input |
4 x BNC inputs |
8 x BNC inputs |
16 x BNC inputs |
| Capture Resolution |
Up to VGA resolution -720x480 (NTSC) / 720x576 (PAL) |
| Total Frame |
120 fps |
240 fps |
480 fps |
| Audio Input |
4 inputs |
8 inputs |
16 inputs |
| Support Software |
Operating System |
Windows XP with SP2 , Windows 2000 with SP4 |
| DirectX support |
Version 9 or above |
| Software |
DVR SCode software and Free remote software |
| (Free remote software : Server software, simple client software, IE viewer) |
| Processor System |
CPU |
Intel Celeron M 1.5 GHz |
| Chipset |
Intel 845GV & ICH4 |
| BIOS |
Award BIOS |
| Memory support |
Max. Capacity |
DDR 266/333 up to 1.0 GB ( non-ECC support ) |
| Socket |
184-pin DIMM |
| Graphic |
Chipset |
Chipset integrated VGA controller |
| Memory Size |
Shared system memory up to 64 MB |
| Ethernet |
Interface |
10/100/1000 Base-T |
| Controller |
Intel 82541PI |
| Connector |
RJ-45 |
| Storage |
IDE-1 |
44-pin IDE interface |
| I/O interface |
VGA |
1 x D-Sub 15-pin |
| USB |
2 x USB 2.0 |
| IEEE 1394 |
1 x IEEE 1394 |
| Audio |
AC97 ( Line-in / Line-out / Min-in ) |
| LAN |
1 x RJ-45 |
| PS/2 |
1 x Keyboard/Mouse |
| Power Requirement |
Management |
ACPI 1.0 compliant |
| Power |
Standard ATX PSU |
| Environment |
Temperature |
0 ~ 40¡æ for operating |
| Physical Characteristics |
Mounting |
Desk |
| Weight |
| Dimensions |
273 x 300 x 65mm |
