| Model Name |
CMS-370Q |
CMS-370S |
| Video system |
Video Standard |
Composite for NTSC / PAL |
| Video Input |
4 ~ 16 ( MP-9116 ) |
1~ 4 ( MP-6802 ) |
| Capture Resolution |
Up to VGA resolution -640x480 (NTSC) / 768x576 (PAL) |
| Total Frame |
120/100 fps |
30/25 fps |
| Image Processing |
YUY2 planar formats supported |
| Software Development kit |
Operating System |
Windows XP with SP2 , Windows 2000 with SP4 |
| DirectX support |
Version 9 or above |
| Demo program |
Demo program with SDK |
Completed demo program with Win32 sample code |
| Function |
Video capture , preview |
| Processor System |
CPU |
Intel Penitum M LV 1.4 GHz |
Intel Celeron M 600 MHz |
| Chipset |
Intel 852GME & ICH4 |
| BIOS |
Award 4M BIOS |
| Memory |
Max. Capacity |
DDR 266/333 up to 1.0 GB ( non-ECC support ) |
| Socket |
184-pin DIMM |
| Graphic |
Chipset |
Chipset integrated VGA controller |
| Memory Size |
Shared system memory up to 64 MB |
| Ethernet |
Interface |
10/100 Base-T |
| Controller |
Intel 82562ET |
| Connector |
RJ-45 |
| Storage |
IDE-0 |
Drive bay space for 2.5" HDD |
| IDE-1 |
CompactFlash socket for Type II |
| I/O interface |
VGA |
1 x D-Sub 15-pin |
| USB |
2 x USB 2.0 |
| Serial |
2 x COM ports ( 1 x External & 1 x Internal ) |
| Audio |
AC97 ( Line-in / Line-out / Min-in ) |
| LAN |
1 x RJ-45 |
| PS/2 |
1 x Keyboard/Mouse |
| Power Requirement |
Management |
ACPI 1.0 compliant |
| Power Adapter |
12V DC input for DC jack |
| Environment |
Temperature |
0 ~ 40¡æ for operating |
| Physical Characteristics |
Mounting |
Wall mounting / Desk |
| Dimensions |
1.41 kg |
| Weight |
195 x 110 x 80 mm |
