²úÆ·Ãû³Æ£º EE-260
ÐÍ ºÅ£º EE-260
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
Board Size
114 x 95 mm
CPU  Type
Support VIA Luke CoreFusion processor with 1.0 GHz or 800/533 MHz .
Chipset
VIA Luke and VT8237R .
Memory Type
1 x 200-pin DDR SO-DIMM support up to 2.0 GB .
VGA Interface
Integrates UniChrome Pro IGP 2D/3D Graphics core .
LVDS Interface
24-bit Dual channel LVDS interface. Inverter connector onboard .
Enhanced IDE
UltraATA/100 IDE up to 2 ATAPI .
Series ATA
Integrated Series ATA/RAID controller facilities high-speed data transfer
up to 150MB/s for each of 2 ports .
LAN Interface
10/100Mbps Ethernet port provide by VIA VT6103 .
Audio
VIA VT8237R built -in  AC97 3D audio controller with ALC202A to support 2 channel audio.
USB
4 x Hi-Speed USB2.0 ports .
I/O ports
2 x RS232 ,  Parallel , IrDA , FDD , PS/2 keyboard/mouse .
PCI
Support PCI bus interface .
Digital I/O
Support 8-bit digital I/O .
Watchdog
256-level generates reset programmable watchdog timer
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
