Board Size
ETX Baseboard ( 170 x 170 mm )
Chipset
Realtek8100B for Ethernet
Battery
Lithium Battery for real time clock
Power Requirement
Standard 20-pin ATX power supply
Extended Interface
1 x PCI slot
1 x CompactFlash socket
Internal I/O Ports
1 x RS232/422/485 port
1 x IrDA connector
1 x GPIO port
1 x 40-pin IDE connector
1 x LVDS and LCD inverter connector
1 x Audio Front Panel with Amplified Speaker out & MIC-in
1 x 20-pin ATX power connector
1 x 40pin & 1 x 44-pin IDE connector
External I/O Ports
1 x PS2 Keyboard/Mouse port
1 x DB9 series port
1 x DB25 LPT port
1 x DB15 CRT port
4 x USB2.0 ports
2 x RJ45 LAN port
1 x 3 port phone jack
