Form Factor |
PICMG 1.3 SBC (338 x 126 mm) |
CPU |
Intel® Core8482; 2 Duo (Merom) processor @ 800 MHz FSB |
Memory |
2 x DDR2 533/667 MHz DIMM up to 3.0 GB |
Chipset |
Intel® GME965 & ICH8M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel® GME965 integrated GMA (Graphic Media Accelerator) X3100 Technology |
Video Memory |
Up to 384 MB shared with system memory |
Serial ATA Interface |
3 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82573L Gigabit Ethernet |
Solid State Disk |
IDE support 40-pin DiskOnModule,1 x CompactFlash Type-II |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
2 x Min-PCI sockets |
External I/O Port |
RJ45 LAN port, 1 x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports |
| Internal I/O Port |
1 xRS232 & 1 x RS232/422/485, 1 x FDD, 1 x IrDA, 1 x LPT
1 x Audio, 6 x USB 2.0, 1 x 8-bit GPIO, 1 x CDIN,
LVDS and LCD inverter connector |
Power Requirement |
+5V, +12V & 5VSB |
| Board Dimension |
338mm x 126 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
