ÏÖ»õ¹©Ó¦¸»Ê¿¡¢¶«Ö¥¡¢ÈýÁâ¡¢ÈÕÁ¢¡¢Î÷ÃÅ¿µ¡¢Î÷ÃÅ×Ó¡¢Å·ÅÉ¿Ë¡¢ABB¡¢IXYSµÈȫϵÁй¤¿Ø²úÆ·
±¾ÖÐÐÄ¿â´æÌؼ۹©Ó¦±äƵÆ÷¡¢ËÅ·þ¡¢ºãѹ¹©Ë®¿ØÖƹñ¡¢µçÆø¹¤³Ì¼°Î¬ÐÞµçÁ¦µç×ÓÆ÷¼þ¡¢GIR¡¢IGBT¡¢IPM¡¢µçÔ´Ä£¿é¡¢VICOR LAMBDA LECENT¡¢TRT¡¢C&D¡¢AC/DC¡¢DC/DC£¬
¸»Ê¿¡¢¶«Ö¥¡¢ÈýÁâ¡¢ÈÕÁ¢¡¢Î÷ÃÅ¿µ¡¢Î÷ÃÅ×Ó¡¢Å·ÅÉ¿Ë¡¢ABB¡¢IXYSµÈȫϵÁй¤¿Ø²úÆ·£¬
ÏÖÓдóÁ¿¿â´æ£¬ÇÒ¼Û¸ñµÍÁ®¡¢·þÎñÖܵ½¡£Ò»ÑùµÄÆ·Öʲ»Ò»ÑùµÄ¼Û¸ñ£¡£¡£¡
¿ÉÀ´µçÃâ·ÑË÷È¡¸»Ê¿¡¢°²´¨±äƵÆ÷˵Ã÷Ê飡
¹²Í¬Ì½ÌÖ±äƵÆ÷¡¢IGBT¡¢GTRµÈ¼¼ÊõÓ¦Óã¡
ÈýÁâMITSUBISHI IGBTÄ£¿é+µ¥¹ÜIGBT(TO¡ª220¡¢TO¡ª3P)(ÄÍѹ600/1200/1400/1700/2500/3300V)
ÐͺŠ¼¼ÊõÖ¸±ê ÐͺÅ(IGBT µ¥¹Ü) ¼¼ÊõÖ¸±ê
CT60AM-20 60A/1000V IGBTµ¥¹Ü CT75SM-12
CT30SM-12 30A/600V IGBTµ¥¹Ü CT15SM-24 15A/1200V IGBTµ¥¹Ü
CT35SM-8 200A/400V IGBTµ¥¹Ü CT75AM-12 75A/600V IGBTµ¥¹Ü
ÐͺŠ¼¼ÊõÖ¸±ê ÐͺŠ¼¼ÊõÖ¸±ê
CM300HA-12H 300A/600V/1U CM200HA-24H 200A/1200V/1U
CM400HA-12H 400A/600V/1U CM300HA-24H 300A/1200V/1U
CM600HA-12H 600A/600V/1U CM400HA-24H 400A/1200V/1U
CM600HU-12H 600A/600V/1U CM600HA-24H 600A/1200V/1U
CM400HU-24H 400A/1200V/1U CM600HU-24H 600A/1200V/1U
CM200HU-24H 200A/1200V/1U CM800HA-24H 800A/1200V/1U
CM300HU-24H 300A/1200V/1U CM1000HA-24H 1000A/1200V/1U
CM300HA-12E 300A/600V/1U CM200HA-24E 200A/1200V/1U
CM400HA-12E 400A/600V/1U CM300HA-24E 300A/1200V/1U
CM600HA-12E 600A/600V/1U CM400HA-24E 400A/1200V/1U
CM600HU-12E 600A/600V/1U CM600HA-24E 600A/1200V/1U
CM400HU-24E 400A/1200V/1U CM600HU-24E 600A/1200V/1U
CM200HU-24E 200A/1200V/1U CM800HA-24E 800A/1200V/1U
CM300HU-24E 300A/1200V/1U CM1000HA-24E 1000A/1200V/1U
CM400HA-28H 400A/1400V/1U CM800HA-50H 800A/2500V/1U
CM600HA-28H 600A/1400V/1U CM1200HA-50H 1200A/2500V/1U
CM1000HA-28H 1000A/1400V/1U CM800HA-66H 800A/3300V/1U
CM400HA-34H 400A/1700V/1U CM1200HA-66H 1200A/3300V/1U
CM800HD-66H 800A/3300V/1U CM800HD-50H 800A/2500V/1U
CM1200HD-66H 1200A/3300V/1U CM1200HD-50H 1200A/2500V/1U
CM50DY-12H 50A/600V/2U CM50E3Y-12E 50A/600V/2U
CM75DY-12H 75A/600V/2U CM75E3Y-12E 75A/600V/2U
CM100DY-12H 100A/600V/2U CM100E3Y-12E 100A/600V/2U
CM150DY-12H 150A/600V/2U CM150E3Y-12E 150A/600V/2U
CM200DY-12H 200A/600V/2U CM200E3Y-12E 200A/600V/2U
CM300DY-12H 300A/600V/2U CM300E3Y-12E 300A/600V/2U
CM400DY-12H 400A/600V/2U CM50E3U-12E 50A/600V/2U
CM75DU-12H 75A/600V/2U CM75E3U-12E 75A/600V/2U
CM100DU-12H 100A/600V/2U CM100E3U-12E 100A/600V/2U
CM150DU-12H 150A/600V/2U CM150E3U-12E 150A/600V/2U
CM200DU-12H 200A/600V/2U CM200E3U-12E 200A/600V/2U
CM300DU-12H 300A/600V/2U CM300E3U-12E 300A/600V/2U
CM400DU-12H 400A/600V/2U CM75DU-12E 75A/600V/2U
CM50DY-12E 50A/600V/2U CM100DU-12E 100A/600V/2U
CM75DY-12E 75A/600V/2U CM150DU-12E 150A/600V/2U
CM100DY-12E 100A/600V/2U CM200DU-12E 200A/600V/2U
CM150DY-12E 150A/600V/2U CM300DU-12E 300A/600V/2U
CM200DY-12E 200A/600V/2U CM400DU-12E 400A/600V/2U
CM300DY-12E 300A/600V/2U CM400DY-12E 400A/600V/2U
CM50DY-24H 50A/1200V/2U CM300DY-28H 300A/1400V/2U
CM75DY-24H 75A/1200V/2U CM50E3Y-24E 50A/1200V/2U
CM100DY-24H 100A/1200V/2U CM75E3Y-24E 75A/1200V/2U
CM150DY-24H 150A/1200V/2U CM100E3Y-24E 100A/1200V/2U
CM200DY-24H 200A/1200V/2U CM150E3Y-24E 150A/1200V/2U
CM300DY-24H 300A/1200V/2U CM200E3Y-24E 200A/1200V/2U
CM50DU-24H 50A/1200V/2U CM50E3U-24E 50A/1200V/2U
CM75DU-24H 75A/1200V/2U CM75E3U-24E 75A/1200V/2U
CM100DU-24H 100A/1200V/2U CM100E3U-24E 100A/1200V/2U
CM150DU-24H 150A/1200V/2U CM150E3U-24E 150A/1200V/2U
CM200DU-24H 200A/1200V/2U CM200E3U-24E 200A/1200V/2U
CM300DU-24H 300A/1200V/2U CM300E3Y-24E 300A/1200V/2U
CM50DY-24E 50A/1200V/2U CM50DU-24E 50A/1200V/2U
CM75DY-24E 75A/1200V/2U CM75DU-24E 75A/1200V/2U
CM100DY-24E 100A/1200V/2U CM100DU-24E 100A/1200V/2U
CM150DY-24E 150A/1200V/2U CM150DU-24E 150A/1200V/2U
CM200DY-24E 200A/1200V/2U CM200DU-24E 200A/1200V/2U
CM300DY-24E 300A/1200V/2U CM300DU-24E 300A/1200V/2U
CM50DY-28H 50A/1400V/2U CM300E3U-24E 300A/1200V/2U
CM75DY-28H 75A/1400V/2U CM400DY-50H 400A/2500V/2U
CM200DY-28H 200A/1400V/2U CM400DY-66H 400A/3300V/2U
CM15TF-12H 15A/600V/6U CM15TF-24H 15A/1200V/6U
CM20TF-12H 20A/600V/6U CM20TF-24H 20A/1200V/6U
CM30TF-12H 30A/600V/6U CM30TF-24H 30A/1200V/6U
CM50TF-12H 50A/600V/6U CM50TF-24H 50A/1200V/6U
CM75TF-12H 75A/600V/6U CM75TF-24H 75A/1200V/6U
CM100TF-12H 100A/600V/6U CM100TF-24H 100A/1200V/6U
CM150TF-12H 150A/600V/6U CM50TF-28H 50A/1400V/6U
CM75TU-12H 75A/600V/6U CM50TU-24H 50A/1200V/6U
CM100TU-12H 100A/600V/6U CM75TU-24H 75A/1200V/6U
CM150TU-12H 150A/600V/6U CM100TU-24H 100A/1200V/6U
CM15TF-12E 15A/600V/6U CM15TF-24E 15A/1200V/6U
CM20TF-12E 20A/600V/6U CM20TF-24E 20A/1200V/6U
CM30TF-12E 30A/600V/6U CM30TF-24E 30A/1200V/6U
CM50TF-12E 50A/600V/6U CM50TF-24E 50A/1200V/6U
CM75TF-12E 75A/600V/6U CM75TF-24E 75A/1200V/6U
CM100TF-12E 100A/600V/6U CM100TF-24E 100A/1200V/6U
CM150TF-12E 150A/600V/6U CM50TU-24E 50A/1200V/6U
CM75TU-12E 75A/600V/6U CM75TU-24E 75A/1200V/6U
CM100TU-12E 100A/600V/6U CM100TU-24E 100A/1200V/6U
CM150TU-12E 150A/600V/6U CM50TF-28H 50A/1400V/6U
CM200TU-12H 200A/600V/6U CM75TF-28H 75A/1400V/6U
