Form Factor |
Half-size PISA CPU Card |
CPU |
Intel® CoreTM 2 Qaud / Core 2 Duo in LAG775 @ 800/1066/1333 MHz FSB. |
Memory |
1 x DDRII SO-DIMM 667/800 MHz up to 2.0 GB |
Chipset |
Intel® Q35 & ICH9DO |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel® Q35 integrated GMA (Graphic Media Accelerator) 3100 Technology |
| LVDS Interface |
Optional 24-bit Dual-channel LVDS interface |
| DVI Interface |
Optional 26-pin DVI interface |
Video Memory |
Up to 384MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA Interface with 300 MB/s transfer rate. Support RAID 0/1/5/10 and Intel® Matrix Storage Technology |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
1 x Intel® 82573L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
External I/O Port |
1 x RJ45 LAN port, 1 x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 1 x RS232 |
| Internal I/O Port |
1 x RS232 & 1 x RS232/422/485, 1 x IrDA , 1 x 5-pin AT KB ,
4 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN , 1x DVI or
LVDS and LCD inverter connector . |
Power Requirement |
+5V , +12V input & 5VSB Requirement |
| Board Dimension |
185mm x 127 mm (L x W) |
Operation Temperature |
0 ~ 60 ¡æ |
