Form Factor: Mini-ITX with 6.7 x 6.7 inches (17 x 17cm) of dimension
CPU: Onboard embedded VIA C7 1.5 GHz CPU
DRAM: 2 x 240-pin DDR2 400/533/667 SDRAM up to 4.0 GB
Chipset: VIA CN896 and VT8251
PCI Enhanced IDE: UltraATA IDE channels up to 4 ATAPI. (1 x 40-pin & 1 x 44-pin)
External I/O Ports: 1x PS/2 keyboard and mouse, 2 x LAN, 6 x USB, 1 x COM, 1 x VGA, 1 x HD Audio, 1 x SPDIF
Internal I/O Ports: 1 x RS232/422/485, 1 x LPT, 1 x IrDA, 1 x GPIO, 1 x Audio, 1 x FDD, 1 x LVDS or DVI, 2 x USB
DVI Interface: Optional onboard DVI interface ( LV-66AD )
LVDS Interface: Optional 18/24-bit LVDS interface ( LV-66AX )
Serial ATA: 4 x SATA with 300 MB/s transfer rate with RAID 0/1/0+1/5
Audio: Realtek ALC888 7.1 channel HD codec
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
LAN Interface: 2 x Realtek 8111C Giga Ethernet controller ( LV-66AX & LV-66AD only )
SSD: IDE support 44-pin DOM with +5V power supply, and CompactFlash Type-II socket in the rear side ( Optional )
Watchdog Timer: Winbond W83697UF with system generates 256 level reset
Expansive Interface: 1 x Slim PCI slot , 1 x Mini-PCI
Power Requirement: Standard 20-pin ATX power supply
