²úÆ·Ãû³Æ£º CMB-672
ÐÍ ºÅ£º CMB-672
Æ· ÅÆ£º 735
Form Factor Mini-ITX barebone system
Construction  Heavy-Duty steel
Mini-ITX Board  Inside Motherboatd can be :
 LV-674 : Intel Pentium D / Pentium 4 /  Celeron D
 LV-672 : Intel Pentium 4 / Celeron
 LV-677 : Intel Core Duo / Core Solo
Drive Bay  External 1 x Slim CD-ROM & 1 x Slim FDD Space
 Internal  2 x 3.5" HDD Space
Riser card  1 x PCI-Express riser card
Thermal Control  One 12 cm system cooling Fan
Front Panel  System Reset switch
 Power On/Off and HDD activity
 2 x USB ports
Rear Side I/O  Depend on Mini-ITX I/O plate .
Environment  Operating Temperature: 0 ~ 50C
Power supply  300W ATX power supply
Dimension  305 x 284 x 119 mm
Weight  5.65 kgw , (With Case , Motherboard , power supply)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
