½«´®¿ÚÉ豸Á¬½ÓÖÁWi-Fi 802.11b/b+gÎÞÏßÍøÂç | |
2/1¸öRS-232/422/485´®¿Ú¶Ë¿Ú£¬ËÙ¶È×î¸ß¿É´ï230.4 Kbps | |
͸¹ýÄÚ½¨Ethernet»òWLANÖ´ÐÐWeb-basedÉ趨 | |
Ö§³ÖWindows/Linux COMÇý¶¯³ÌÐò | |
͸¹ýHTTPS, SSH½øÐÐÔ¶³ÌÉ趨 | |
Ö§³ÖTCP Client/Server pair connection modeºÍUDP mode | |
͸¹ý±ê×¼WEP±£»¤´æÈ¡×ÊÁϵݲȫÐÔ |
¾«ÇɵÄÌå»ý£¬¼á¹ÌµÄ½ðÊôÍâ¿ÇÊÊÓÃÓÚÈκÎÓ¦Óà | |
ÎÞÏß¾ÖÓòÍø | |
| 15 dBm ¡À2 (CH1-Ch13), 12dBm ¡À 2 (CH14) | | |
| -84 dBm @ 11 Mbps, -87 dBm @ 5.5 Mbps | | |
| 11 Mbps (max.) with auto fallback (11, 5.5, 2, 1 Mbps) | | |
| ×î¸ß¿É´ï100¹«³ß(@11 Mbps, in open areas) | | |
| WEP 64-bit/128-bit×ÊÁϼÓÃÜ | | |
¿ØÖÆÌ¨¶Ë¿Ú | |
| Ethernet x 1, RS-232 ¿ØÖÆÌ¨¶Ë¿Ú x 1 (Port 1) | | | | |
Èí¼þ¹¦ÄÜ | |
| ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, DNS,SNMP, HTTP, SMTP | | |
| Windows 98/ME/2000/XP/2003 | | |
| Web ä¯ÀÀÆ÷, ´®¿Ú/telnet console, »òÕß Windows ʹÓÃÆ½Ì¨ | | | | |
µçÔ´ÐèÇó | |
| 250 mA @ 12V, 138 mA @ 24V | | | | |
»·¾³ | |
| 0ÖÁ55¡ãC (32ÖÁ131¡ãF),5ÖÁ95% RH | | |
| -20ÖÁ85¡ãC (-4ÖÁ185¡ãF),5ÖÁ95% RH | | | | |
°²¹æÈÏÖ¤ | |
»ú¹¹ | |
77 x 111 x 26 mm (²»º¬¶ú¶ä»òÌìÏß) 100 x 111 x 26 mm (º¬ÌìÏß) | | |
´®¿Ú | |
| RS-232/422/485, 8-pin RJ45 | | |
| 2 ports (NPort W2250), 1 port (NPort W2150) | | | | |
´®¿ÚͨѶ²ÎÊý | |
| None, Even, Odd, Space, Mark | | |
