Form Factor |
Mini-ITXexpress Motherboard (170 x 170 mm) |
CPU |
Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB |
Memory |
1 x DDR3 800/1066 MHz up to 2.0 GB |
Chipset |
Intel® GM45 & ICH9M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
VGA Interface |
Intel® GM45 integrated GMA X4500 Technology |
| LVDS Interface |
24-bit dual channel LVDS interface |
Serial ATA Interface |
4 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82573L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
PCI-Express X16, Min-PCI and PCI Express Mini card |
External I/O Port |
2 x RJ45 LAN ports, 1 x DB15 VGA port,1 x PS/2 Keyboard / Mouse ports, 1 x IEEE 1394 ports, 6 x USB 2.0 ports, Audio, SPDIF, 1 x COM |
| Internal I/O Port |
1 x RS232/422/485, 1 x SMBUS, 1 x IrDA , 4 x USB 2.0,
1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD inverter
connector, 1 x HDTV |
Power Requirement |
Standard 20-pin ATX power supply or
9V ~ 24V full range DC input (8 ~ 30V is operative)
(It won''''t support PCIE graphic card if use DC input mode) |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
