ÉϺ£Íзƻúµç¿Æ¼¼ÓÐÏÞ¹«Ë¾
IFMÒ׸£ÃÅ(ifm)µç×ÓÊÇÒ»¼ÒÈýÊ®¶àÄêÀ´ÔÚÈ«Çò·¶Î§ÄÚÒ»Ö±´ÓÊÂÑо¿,Éú²ú¼°ÏúÊÛÓÃÓÚÐźŵļì²â,¿ØÖƼ°´¦ÀíµÄÔªÆ÷¼þºÍϵͳµÄ¿ç¹ú¼¯ÍÅÆóÒµ¡ªÉæ¼°µÄ²úÆ·´Ó±ê×¼µÄ´«¸ÐÆ÷µ½Ìض¨Ó¦ÓõĿØÖÆÆ÷
98454 EMS-Base FC Adressierst. P+F
98455 EEMS-Base FC Adressierst. P+F
99334 EMS-Base FC P+F
99335 EEMS-Base FC P&F
AC0005 Profikit DEUTSCH
AC0006 Profikit ENGLISH
AC0007 Added Value package AS-i T5
AC0017 Added Value package AS-i T5
AC0019 Added Value package AS-i T5
AC001S Safety monitor/1 channel
AC0020 Added Value package AS-i T5
AC0021 Added Value package AS-i T5
AC0022 Added Value package AS-i T5
AC0023 Added Value package AS-i T5
AC0024 Added Value package AS-i T5
AC002S Safety monitor/2 channel
AC003S Safety monitor/1 ch. enhan.
AC004S Safety monitor/2 ch. enhan.
AC005A ClassicLine 4DI T M12 Atex
AC005S ClassicL45 1DI/2DI M12
AC006S ClassicL90 2SI 2DO T M12
AC007A ClassicL45 2DI 2DO T M12
AC007S BWS-Modul
AC008A ClassicL45 4DO T M12 ATEX
AC009A ClassicLine 4DI 4DO T M12 Atex
AC009S SmartLine SafetyModul
AC010S E-stop illuminated IP67
AC0115 Manual AS-Interface German
AC0116 Manual AS-Interface English
AC011S E-stop key switch IP67
AC014A ClassicL45 2DO-y 2DI-y T M12
AC015S AS-i Safety pcb 2-SI/1-DO
AC016S CL90,Evaluation unit,AS-i
AC0305 System-Software + Handbuch Deu
AC0306 System-Software + Handbuch Eng
AC0307 System-Software + Handbuch Fra
AC0311 System-Software + Handbuch Deu
AC0312 System-Software + Handbuch Eng
AC0314 Controller-Library German
AC0315 System-Software + Handbuch Deu
AC0317 System-Software + Handbuch Deu
AC0325 Controller-Library English
AC0326 Softw.for ControllerE full Ger
AC0327 Softw.for ControllerE full Eng
AC0340 CoDeSys 2.3 CD full f. Cont
AC0346 Manual CoDeSys 2.3 German
AC0347 Manual CoDeSys 2.3 English
AC042A AirBox 2DI 1PO M12 II 3D
AC046A AirBox 2DI 1PO M12 ATEX
AC1004 CONTR 2MSTR 1RS232C
AC1005 Contr 1MSTR 1RS232C 1DP
AC1006 Contr 2MSTR 1RS232C 1DP
AC1008 CONTR/1MSTR/1RS232C/1DN
AC1011 Contr 1MSTR 1RS232C 1RS485
AC1012 Contr 2MSTR 1RS232C 1RS485
AC1015 Repeater 6GK1 210-0SA00 IP67
AC1016 Extender 6GK1 210-1SA00 IP67
AC1018 Controller 1MSTR 1RS232C 1DP
AC1020 Contr 2MSTR 1RS232C 1IBS
AC1023 Contr 1MSTR 1RS232C 1RS232C
AC1053 Master Steckkarte CP2430 f¨¹r
AC1057 Master S7-300 CP343-2 6GK7 343
AC1060 ASI M-MODUL
AC1092 Modbus Gateway RS485 B+W 1037
AC1093 Modbus Plus Gateway V2.1
AC1095 PCB PCI-Card 2 Master
AC1144 Addressing unit AS-i 2.1
AC1145 eAS-i Tester
AC1146 AS-i Tuner IP67
AC1147 AS-i Busabschluss
AC1150 2DI RS485 SEW CCT
AC2254 SmartL25 4DI C
AC2255 SmartL25 4DI 2DO R C
AC2256 SmartL25 4DI 2DO R C
AC2257 SmartL25 4DI 4DO T C
AC2258 SmartL50 4DI 4DO R C
AC2259 SmartL50 4DI 4DO R C
AC2260 SmartLogic 8DI 4DO T 1AO C
AC2264 SmartLine25 4DI 3DO T C
AC2305 DUAL SENSOR T4 2SI M12
AC2307 DUAL SENSOR T6 2SI 2DO T M12
AC2310 DUAL SENSOR T5 2SI 1DO T M12
AC2314 DUAL SENSOR T4 2SI
AC2315 DUAL SENSOR T4 2SI M12
AC2316 DUAL SENSOR T5 2SI 1DO T M12
AC2317 DUAL SENSOR T6 2SI 2DO T M12
AC2351 Push-button modul 8I/8O
AC2410 CompactModule 4DI M12
AC2411 CompactModule 2DI 2DO T M12
AC2412 CompactModule 4DI 4DO T M12
AC2413 CompactModule 4 SB
AC2417 CompactModule 4DO T M12
AC2445 Compactmodul aktiv, 4E/4AT PNP
AC2449 Compactmodul passiv, 4V-E
AC2451 CompactModule 4DI M12 V4A
AC2452 CompactModule 4DI 4DOT M12 V4A
AC2457 CompactLM12 4DI M12 IR IP67
AC2458 CompactLM12 2DI 2DO T M12 IR
AC2459 CompactLM12 4DI 4DO T M12 IR
AC2462 CompactLineM12 4DI4DO T M12
AC2463 CompactLine 8DI M12
AC2464 CompactLineM12 4DI M12
AC2465 CompactLineM12 4DI 4DO M12
AC2466 CompactLineM12 4DI4DO T M12
AC2480 CompactLine M8 4DI
AC2500 ClassicLine45 4 SB
AC2501 ClassicLine45 4DI FKT M12
AC2502 ClassicLine45 2x(2DI/1DO T)M12
AC2503 ClassicLine 3DO T M12
AC2504 ClassicLine 4DI 3DO T M12
AC2505 ClassicLine45 4DI M12
AC2506 ClassicLine 2x(2DI) M12
AC2507 ClassicL45 2DI 2DO T M12
AC2508 ClassicLine45 4DO T M12
AC2509 ClassicLine90 4DI 4DO T M12
AC2514 ClassicL45 2DO-y 2DI-y T M12
AC2515 ClassicLine 4DI M12
AC2516 ClassicLine90 4AI (C) M12 IP67
AC2517 ClassicLine90 4AI (V) M12 IP67
AC2518 ClassicLine90 4AO (C) M12 IP67
AC2519 ClassicLine90 4AO (V) M12 IP67
AC2520 ClassicL90 4AI(Pt100) M12 IP67
AC2521 ClassicL90 4AO (C) M12 IP67
AC2524 ClassicLine90 2X(2DI 1DO T)M12
AC2526 ClassicLine90 4AI M12 IP67
AC2602 PZB 4DI 4DO T
AC2606 AnalogModule 4AI Pt100 ST
AC2610 AnalogModule 1AI ST
AC2611 AnalogModule 1A0 ST
AC2616 UniversalModule 2AI(C) IP65
AC2617 UniversalModule 2AI(V) IP65
AC2618 UniversalModule 2AO(C) IP65
AC2619 UniversalModule 2AO(V) IP65
AC2620 UniversalModule 4AI(Pt100)IP65
AC2701 CabinetModule 4DI 4DO T ST
AC2703 CabinetModule 4DI 4DO T ST
AC2704 CabinetModule 4DI 4DO T ST
AC2708 CabinetModule 4DI 4DO T PW
AC2709 CabinetModule 4DI 4DO T W
AC2711 RMQ-M1C-ASI RMQ22 AS-Interface
AC2716 CabinetModule 1LO PW
AC2720 PCB 4DI 4DO T
