²úÆ·Ãû³Æ£º
ÑлªADAM-6521 ´ø¹âÏ˶˿Ú5¶Ë¿Ú10/100Mbps¹¤ÒµÒÔÌ«Íø×ª»»Æ÷
ÐÍ ºÅ£º
ADAM-6521
Ñлª
Ö÷ÒªÌØµã
- ´«Êä¾àÀ루¹âÏË£©£º2000Ã×
- ¹¤×÷ζȣº-10 ~ 65 ¡æ
- °²×°£ºDINµ¼¹ì°²×°£¬Ãæ°å°²×°£¬¶Ñµþ
- ÀËÓ¿±£»¤£º3000 VDC
- ѹÁ¦£º+ 10 ~ 30 VDC
- Ö§³Öȫ˫¹¤/°ëË«¹¤Á÷Á¿¿ØÖÆ
- Ö§³Ö5¶Ë¿Ú100BASE-TX and 10/100BASE-FX
| ¡¡¡¡The ADAM-6521 is an industrial-grade Ethernet hub for infrastructure networking solution in industrial Automation environment. It allows users to cost-effectively expand their industrial network with ease. The ADAM-6521 consists of one fiber optic and four RJ-45 ports. With fiber optic, you can prevent noise interference from the system and transmission distance up to 2 km. The design is focused on industrial-grade reliability and stability. Thus, the ADAM-6521 is especially suited for industrial environments with Ethernet networking needs, e.g. semi-conductor factories, inventory control environments, assembly lines, production and more. | |
