4¶Ë¿Ú10 Mbps¹¤ÒµÒÔÌ«Íø¼¯Ï߯÷
Ö÷ÒªÌØµã
- ¹¤×÷ζȣº-10 ~ 70 ¡æ
- °²×°£ºDINµ¼¹ì°²×°£¬Ãæ°å°²×°£¬¶Ñµþ
- ÀËÓ¿±£»¤£º3000 VDC
- µçѹ£º+ 10 ~ 30 VDC
- Ö§³Ö4¶Ë¿Ú 10 Mbps RJ-45Á¬½ÓÆ÷
| ¡¡¡¡The ADAM-6510 is an industrial-grade Ethernet hub for infrastructure networking solution in industrial Automation environment. It allows users to cost-effectively expand their industrial network with ease. The ADAM-6510 is a 4-port 10 Mbps Ethernet hub, which has four twisted pair ports to connect up to four Ethernet devices. The design is focused on industrial-grade reliability and stability. Thus, the ADAM-6510 is especially suited for industrial environments with Ethernet networking needs, e.g. semi-conductor factories, inventory control environments, assembly lines, production and more. | |
