¼¼Êõ |
IEEE 802.3 10Base-T Ethernet IEEE 802.3u 100Base-TX Fast Ethernet IEEE 802.3x Flow Control and Back-pressure
| ½çÃæ |
5 x 10/100 Base-TX, Auto MDI/MDIX | |
10Base-T: 2-pair UTP/STP Cat. 3, 4, 5 cable, EIA/TIA-568 100-ohm (100m) 100Base-TX: 2-pair UTP/STP Cat. 5 cable, EIA/TIA-568 100-ohm (100m) | |
¶Ë¿Ú: Link/Activity (ÂÌÉ«), Full duplex/Collision (ÂÌÉ«) É豸: Power x 3 (ÂÌÉ«) | |
| ÐÔÄÜ |
ÒÔÌ«¶Ë¿Ú14,880 pps ¡£¸ßËÙÒÔÌ«¶Ë¿Ú148,800 pps | |
64 bytes ÖÁ 1522 bytes (with VLAN tag) | |
| µçÔ´ÐèÇó |
Ò»¸ö¿É²ðж6-pin terminal blockÌṩ24VDC (12ÖÁ36VDC), ˫ֱÁ÷µçÔ´ÊäÈ룬¾ß±¸µçÔ´Õý¸º¼«ÐÔ·´½Ó±£»¤ | |
| »úе¹æ¸ñ |
IP-30¹¤Òµ·À»¤±ê×¼£¬ÂÁÖÆÍâ¿Ç | |
53 mm (W) x 135 mm (H) x 105mm (D) | |
| ¹¤×÷»·¾³ |
-40 ÖÁ 80¡æ (-40 ÖÁ 176¡ãF) | |
-40 ÖÁ 85¡æ (-40 ÖÁ 185¡ãF) | |
| ͨ¹ýÈÏÖ¤ |
FCC Class A, EN 55022 Class A
EN61000-4-2, EN61000-4-3, EN61000-4-4 EN6100-4-5, EN6100-4-6, EN6100-4-8, EN6100-4-11 | |
