4µç¿Ú1¹â¿Ú¹¤Òµ¼¶ÒÔÌ«Íø½»»»»ú
- ÂÁÖÆÍâ¿Ç£¬·ûºÏIP30¹¤Òµ·À»¤±ê×¼
- ´æ´¢ºÍת·¢½»»»¼Ü¹¹
- Ö§³Ö°ëË«¹¤/ȫ˫¹¤Á÷Á¿¿ØÖÆÒÔ¼°10/100TX¶Ë¿ÚÌṩ×ÔÊÊÓ¦MDI/MDI-X¹¦ÄÜ
- Ìá¹©ÕæÊµÎÞ¶ÂÈû¡¢½»»»»úÖÆ
- DIN-Railµ¼¹ì¡¢±Ú¹Ò»òÊÇ×ÀÃæÈýÖÖ°²×°·½Ê½
- ÈßÓà˫ֱÁ÷µçÔ´ÊäÈë
¡¡¡¡JetNet 3005fÊÇÒ»¿îµÍ³É±¾ÈëÃż¶µÄ5¿Ú¹¤ÒµÒÔÌ«Íø½»»»»ú£¬Õâ¿î¹¤Òµ¼¶½»»»»ú³ýÁ˳ýÁ˾߱¸ËùÓзǹÜÀí½»»»»úµÄÌØÐÔÖ®Í⣬»¹²ÉÓÃÂÁÖÆÍâ¿ÇÉè¼Æ£¬·ûºÏIP30¹¤Òµ±£»¤±ê×¼¡£JetNet 3005f¾ß±¸4¸ö10/100Base-TX¶Ë¿ÚÒÔ¼°1¸ö100Base-FX¹âÏ˶˿ڡ£Í¨¹ý¹âÏ˶˿ڿɽ«Í¨ÐžàÀëÑÓ³¤µ½2¹«À¶àÄ££©»òÊÇ30¹«Àµ¥Ä££©¡£ÎªÁËÒª·ûºÏ¹¤Òµ×°ÖõçÔ´ÈßÓàÐèÇó£¬JetNet 3005fͨ¹ýterminal block½Ó¿ÚÌṩÈßÓàË«µçÔ´ÊäÈ빦ÄÜÒÔ¼°Õý¸º¼«ÐÔ·´½Ó±£»¤¹¦ÄÜ¡£²ÉÓÃÁË´æ´¢ºÍת·¢½»»»¼Ü¹¹¿ÉÓÐЧÔö¼ÓÍøÂç´«ÊäЧÂÊ£¬Òò´Ë½»»»»úÉÏËùÓеIJº¿ÉÒÔÔÚÈ«ËÙÔË×÷ÏÂÌá¹©ÕæÊµÎÞ¶ÂÈû½»»»Êý¾Ý£¬ÇÒ´«ÊäÉϲ»»áÓÐÈκÎÊý¾ÝÒÅʧ¡£
¼¼Êõ |
IEEE 802.3 10Base-T Ethernet IEEE 802.3u 100Base-TX Fast Ethernet IEEE 802.3x Flow Control and Back-pressure
| ½çÃæ |
4 x 10/100 Base-TX, Auto MDI/MDIX, 1 x 100 Base-FX
10Base-T: 2-pair UTP/STP Cat. 3, 4, 5 cable, EIA/TIA-568 100-ohm (100m) 100Base-TX: 2-pair UTP/STP Cat. 5 cable, EIA/TIA-568 100-ohm (100m) | |
SC (¶àÄ£): 50/125um to 62.5/125um SC (µ¥Ä£): 9/125um to 10/125um ¾àÀë : 2km (¶àÄ£) / 30km (µ¥Ä£) ²¨³¤: 1310nm (¶àÄ£/µ¥Ä£) | |
¶Ë¿Ú: Link/Activity (ÂÌÉ«), Full duplex/Collision (ÂÌÉ«) É豸: Power x 3 (ÂÌÉ«) | |
| ÐÔÄÜ |
ÒÔÌ«¶Ë¿Ú14,880 pps ¡£¸ßËÙÒÔÌ«¶Ë¿Ú148,800 pps | |
64 bytes ÖÁ 1522 bytes (with VLAN tag) | |
| µçÔ´ÐèÇó |
Ò»¸ö¿É²ðж6-pin terminal blockÌṩ24VDC (12ÖÁ36VDC), ˫ֱÁ÷µçÔ´ÊäÈ룬¾ß±¸µçÔ´Õý¸º¼«ÐÔ·´½Ó±£»¤ | |
| »úе¹æ¸ñ |
IP-30¹¤Òµ·À»¤±ê×¼£¬ÂÁÖÆÍâ¿Ç | |
53 mm (W) x 135 mm (H) x 105mm (D) | |
| ¹¤×÷»·¾³ |
-10 ÖÁ 70¡æ (14 ÖÁ 158¡ãF) | |
-40 ÖÁ 85¡æ (-40 ÖÁ 185¡ãF) | |
| ͨ¹ýÈÏÖ¤ |
FCC Class A, EN 55022 Class A
EN61000-4-2, EN61000-4-3, EN61000-4-4 EN6100-4-5, EN6100-4-6, EN6100-4-8, EN6100-4-11 | |
380,973Сʱ(ʹÓÃMIL-HDBK-217F GBÃÀ¹ú¾ü¹æ±ê×¼¼ÆËã) | |
JetNet 3005f-m 4¿Ú10/100Base-Tx£¬1¿Ú¶àÄ£¹âÏË£¬¹¤Òµ¼¶ÒÔÌ«Íø½»»»»ú °üº¬£º
- 4¿Ú10/100Base-Tx£¬1¿Ú¶àÄ£100Base-FX½»»»»ú
- ¿ìËÙ°²×°µ¼ÒýÊÖ²á
- Óû§ÊÖ²á¹âÅÌ
- ±Ú¹ÒÅä¼þÒÔ¼°6¿ÅÂÝË¿¶¤
JetNet 3005f-s 4¿Ú10/100Base-Tx£¬1¿Úµ¥Ä£¹âÏË£¬¹¤Òµ¼¶ÒÔÌ«Íø½»»»»ú °üº¬£º
- 4¿Ú10/100Base-Tx£¬1¿Úµ¥Ä£100Base-FX½»»»»ú
- ¿ìËÙ°²×°µ¼ÒýÊÖ²á
- Óû§ÊÖ²á¹âÅÌ
