¼¼Êõ |
IEEE 802.3 10Base-T Ethernet IEEE 802.3u 100Base-TX Fast Ethernet IEEE 802.3x Flow Control and Back-pressure ×ÔÊÊÓ¦ MDI/MDIX | |
| ½çÃæ |
10Base-T: 2-pair UTP/STP Cat. 3, 4, 5 cable, EIA/TIA-568 100-ohm (100m) 100Base-TX: 2-pair UTP/STP Cat. 5 cable, EIA/TIA-568 100-ohm (100m) | |
¶Ë¿Ú: Link/Activity (ÂÌÉ«), Full duplex/Collision (ÂÌÉ«) É豸: Power x 3 (ÂÌÉ«), Fault (Red), R.M (³ÈÉ«) | |
¿É²ðжʽ6-pin terminal block¼ÌµçÆ÷±¨¾¯Êä³ö | |
| ¹ÜÀí |
ÿ¸öswitchÉÏÓÐÁ½¸ö¶Ë¿Ú¿ÉÓÃÀ´Á¬ÎªSuper Ring»·×´ÈßÓàÍøÂ磬Ìṩ±¸Ô®Ïß·¡£Super RingµÄÍøÂç»Ø¸´Ê±¼ä<300ºÁÃ룬¿É͸¹ýWebä¯ÀÀÆ÷½øÐÐÆô¶¯¡£ | |
| ÐÔÄÜ |
ÒÔÌ«¶Ë¿Ú14,880 pps ¡£¸ßËÙÒÔÌ«¶Ë¿Ú148,800 pps
| µçÔ´ÒªÇó |
| Ò»¸ö¿É²ðж6-pin terminal blockÌṩ12ÖÁ36VDC˫ֱÁ÷µçÔ´ÊäÈ룬¾ß±¸µçÔ´Õý¸º¼«ÐÔ·´½Ó±£»¤ | |
| »úе³ß´ç |
µ¼¹ì¡¢±Ú¹Ò¡¢×ÀÃæ3ÖÖ°²×°Ä£Ê½ | |
IP-30¹¤Òµ·À»¤±ê×¼£¬ÂÁÖÆÍâ¿Ç | |
53 mm (W) x 135 mm (H) x 105mm (D) | |
| ÊÊÓû·¾³ |
-10 to 70¡æ (14 to 158¡ãF) | |
-40 to 85¡æ (14 to 185¡ãF) | |
| °²¹æÈÏÖ¤ |
·ûºÏ: FCC Class A ·ûºÏEN61000-4-2, EN61000-4-3, EN61000-4-4 ·ûºÏEN6100-4-5, EN6100-4-6, EN6100-4-8, EN6100-4-11 | |
·ûºÏUL, cUL, EN60950¹ú¼Ê±ê×¼
·ûºÏIEC 60068-2-27¹ú¼Ê±ê×¼ | |
·ûºÏIEC 60068-2-32¹ú¼Ê±ê×¼ | |
·ûºÏIEC 60068-2-6¹ú±ê±ê×¼ | |
319,175Сʱ * ʹÓÃMIL-HDBK-217F ¹æÔò¼ÆËã (MIL-HDBK-217FÊÇÓÃÃÀ¹ú¹ú·À²¿Ëù·¢Õ¹³öÀ´µÄ¾üÓùæ¸ñµç×Ó¿É¿¿¶È±ê×¼£¬Í¸¹ý¸Ã±ê×¼¿É¼ÆËã³ö²úÆ·µÄ¿É¿¿¶ÈÒÔ¼°Ô¤¹À²úÆ·ÊÙÃü) | |
