¼¼Êõ |
IEEE 802.3 10Base-T Ethernet IEEE 802.3u 100Base-TX Fast Ethernet IEEE 802.3x Flow Control and Back-pressure IEEE 802.1p class of service IEEE 802.1Q VLAN | |
| ½çÃæ |
8 x 10/100 Base-TX, Auto MDI/MDIX | |
10Base-T: 2-pair UTP/STP Cat. 3, 4, 5 cable, EIA/TIA-568 100-ohm (100m) 100Base-TX: 2-pair UTP/STP Cat. 5 cable, EIA/TIA-568 100-ohm (100m) | |
¶Ë¿Ú: Link/Activity (ÂÌÉ«), Full duplex/Collision (ÂÌÉ«) É豸: Power x 3 (ÂÌÉ«), Fault (ºìÉ«), R.M (³ÈÉ«) | |
µ±ÍøÂç¶ÏÏß»òµçÔ´¹ÊÕÏʱ£¬¼ÌµçÆ÷±¨¾¯Êä³ö | |
| ÈßÓà |
Super Ring»·×´ÍøÂçÈßÓ༼Êõ£¬»Ø¸´Ê±¼äÉÙÓÚ300ºÁÃë RSTP£¬STP | |
| ¹ÜÀí |
IGMP V1& Query mode, DHCP/Client, TFTP, SNTP | |
ͨ¹ýWeb½çÃæÀ´¹ÜÀí 1¸ö¼æ¾ß×°ÖÃÖØÖúͻظ´ÏµÍ³Ä¬ÈÏÖµµÄ°´Å¥
Ö§³ÖPort-based VLANÒÔ¼°IEEE802.1Q Tag VLAN
ÿ¸ö²ºÌṩ4ÖÖÁ÷Á¿ÓÅÏÈȨѡÔñ
ÓÚÑ¡ÔñµÄ¶Ë¿ÚÉϽøÐÐÔÚÏßÁ÷Á¿¼à¿Ø
¿ÉÓÃÔ¤ÏÈÉ趨µÄIPµØÖ·À´¿Ø¹Ü´æÈ¡
| ÐÔÄÜ |
ÒÔÌ«¶Ë¿Ú14,880 pps ¡£¸ßËÙÒÔÌ«¶Ë¿Ú148,800 pps
64 bytesÖÁ1522 bytes(with VLAN tag) | |
| µçÔ´ÒªÇó |
| Ò»¸ö¿É²ðж6-pin terminal blockÌṩ12ÖÁ36VDC˫ֱÁ÷µçÔ´ÊäÈ룬¾ß±¸µçÔ´Õý¸º¼«ÐÔ·´½Ó±£»¤ | |
| »úе³ß´ç |
µ¼¹ì¡¢±Ú¹Ò¡¢×ÀÃæ3ÖÖ°²×°·½Ê½ | |
IP-30¹¤Òµ·À»¤±ê×¼£¬ÂÁÖÆÍâ¿Ç | |
53 mm (W) x 135 mm (H) x 105mm (D) | |
| ÊÊÓû·¾³ |
-10 to 70¡æ (14 to 158¡ãF) | |
-40 to 85¡æ (14 to 185¡ãF) | |
| °²¹æÈÏÖ¤ |
·ûºÏEN61000-4-2, EN61000-4-3, EN61000-4-4 ·ûºÏEN61000-4-5, EN61000-4-6, EN61000-4-8, EN61000-4-11
·ûºÏUL, cUL, EN60950¹ú¼Ê±ê×¼
·ûºÏIEC 60068-2-27¹ú¼Ê±ê×¼ | |
·ûºÏIEC 60068-2-32¹ú¼Ê±ê×¼ | |
·ûºÏIEC 60068-2-6¹ú±ê±ê×¼ | |
319,175Сʱ(ʹÓÃMIL-HDBK-217F GBÃÀ¹ú¾ü¹æ±ê×¼¼ÆËã)
