Form Factor |
3.5" Miniboard (146 x 101 mm) |
CPU |
Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB |
Memory |
1 x DDR3 SO DIMM support 800/1066 MHz up to 2.0 GB |
Chipset |
Intel® GM45 & ICH9M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
VGA Interface |
Intel® GM45 integrated GMA X4500 Technology |
| LVDS Interface |
24-bit dual channel LVDS interface |
Serial ATA Interface |
2 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
Min-PCI and PCI Express Mini card sockets |
External I/O Port |
2 x RJ45 LAN , 1 x SPDIF , 1 x PS/2 Keyboard / Mouse , 1 x VGA , 1 x COM |
| Internal I/O Port |
1 x RS232/422/485, 1 x SMBUS, 1 x IrDA , 4 x USB 2.0,
1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD inverter
connector, 1 x HDTV |
Power Requirement |
DC 12V input |
| Board Dimension |
146mm x 101mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
