Form Factor |
Hall-size ISA-bus CPU Card |
CPU |
Supports Intel Pentium M & Celeron M processors with FC-PGA(478 pins) & FC-BGA(479pins) |
Memory |
1x184 pin DDR DIMMs to support up to 1.0GB DDR266/333 SDRAM Supports unbuffered ECC memory. |
Chipset |
Intel 82855GME & ICH4 |
Watchdog Timer |
256-level generates system reset programmable watchdog timer |
Real Time Clock |
Intel ICH4 integrated RTC with onboard lithium battery |
| Power Manegement |
ACPI 1.0 compliant, supports power saving mode with ATX PSU, RTC alarm, Software shutdown, Wake on LAN |
PCI Enhanced IDE |
Supports two IDE channels & up to four IDE drivers Supports ¡°Ultra DMA 33/66/100¡± |
VGA Interface |
Intel 855GME GMCH built-in 256bit 2D/3D VGA controller, Dynamic video memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 2x8-pin header |
LVDS |
Supports up to 24-bit Dual LVDS TFT LCD panel Inverter connector on board |
LAN Interface |
Intel 82541PI Gigabit Ethernet Controller. |
Audio Interface |
Intel ICH4 built-in AC97 3D audio controller with ALC201A |
Multi-I/O Port |
1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 2 USB 2.01 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard connector |
Solid State Disk |
Onboard Compact Flash Type-II socket |
Environment |
+5V & +12V DC input from backplane. Operation Temperature: 0 ~ 60oC (32 ~ 140oF) |
