Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú HS-870SCM6
²úÆ·Ãû³Æ£º HS-870SCM6
ÐÍ ºÅ£º HS-870SCM6
Æ· ÅÆ£º 735
Form Factor
Hall-size ISA-bus CPU Card
CPU
Onboard Intel® ULV Celeron M 600MHz  @400MHz FSB uFCBGA CPU
Memory
1x184 pin DDR DIMM to support up to 1.0GB DDR266 SDRAM Supports unbuffered ECC memory.
Chipset
Intel® 82852GM & ICH4
Watchdog Timer
256-level generates system reset programmable watchdog timer
Real Time Clock
Intel® ICH4 integrated RTC with onboard lithium battery
Power Management
ACPI 1.0 compliant, supports power saving mode with ATX PSU, RTC alarm, Software shutdown, Wake on LAN
PCI Enhanced IDE
Supports two IDE channels & up to four IDE drivers Supports ¡°Ultra DMA 33/66/100¡±
VGA Interface
Intel® 852GM GMCH built-in 256bit 2D/3D VGA controller, Dynamic video memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 2x8-pin header
LVDS
Supports up to 24-bit Dual LVDS TFT LCD panel Inverter connector on board
LAN Interface
Intel® 82541PI Gigabit Ethernet Controller.
Audio Interface
Intel® ICH4 built-in AC97 3D audio controller with ALC201A
Multi-I/O Port
1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 2 USB 2.01 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard connector
Solid State Disk
Onboard Compact Flash Type-II socket
Environment
+5V & +12V DC input from backplane. Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
