Form Factor |
5.25" Miniboard (203 x 146 mm) |
CPU |
Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB |
Memory |
2 x DDR3 SO DIMM support 800/1066 MHz up to 4.0 GB |
Chipset |
Intel® GM45 & ICH9M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel® GM45 integrated GMA X4500 Technology |
| LVDS Interface |
24-bit dual channel LVDS interface |
| DVI Interface |
Onboard 26-pin DVI connector ( LS-573TXD only ) |
Serial ATA Interface |
4 x Serial ATA Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
6 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
PCI slot , Min-PCI and PCI Express Mini card sockets |
External I/O Port |
6 x RJ45 LAN, 2 x USB, 1 x DC input, 1 x VGA, 1 x COM |
| Internal I/O Port |
1 x RS232/422/485, 4 x RS232, 1 x IrDA , 4 x USB 2.0,
1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD inverter
connector, 1 x HDTV, 1 x SMBus, 1 x DVI (LS-573TXD only)
1 x VGA (LS-573T2X only) |
Power Requirement |
Standard 20-pin ATX P/S or DC 9V ~ 24V full range input |
| Board Dimension |
203mm x 146mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
