²úÆ·Ãû³Æ£º LE-374
ÐÍ ºÅ£º LE-374
Æ· ÅÆ£º 735
Form Factor
3.5" Miniboard (146 x 101 mm)
CPU
Intel® Atom N270 @ 533 MHz FSB
Memory
1 x DDR2 SO DIMM support 400/533 MHz up to 2.0 GB
Chipset
Intel® 945GSE & ICH7M
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset internal timer for 1sec/min ~ 255 sec/min
Power Management
ACPI 1.0 compliant, supports power saving mode
VGA Interface
Intel® 945GSE integrated GMA 950 Technology
LVDS Interface     18-bit dual channel LVDS interface
DVI Interface     Onboard DVI Transmitter for DVI interface
Serial ATA Interface
2 x Serial ATA II Interface with 150 MB/s transfer rate.
PCI Enhanced IDE     1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices
Solid State Disk    IDE supports 44-pin DiskOnModule +5V  power supply
CompactFlash Type-II .
Audio Interface
Realtek ALC655 5.1ch Audio
LAN Interface
1 x Intel® 82574L Gigabit Ethernet
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
Min-PCI socket
External I/O Port
1 x RJ45 LAN , 1 x  PS/2 Keyboard / Mouse , 2 x USB ,     1 x VGA , 1 x COM
Internal I/O Port
   1 x RS232/422/485, 1 x IrDA , 2 x USB 2.0,
   1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD  inverter
    connector, 1 x HDTV
Power Requirement
Full range DC 9V ~ 24V input (8 ~ 30V is operative)
Board Dimension    146mm x 101mm (L x W)
Operation Temperature
0 ~ 60ºC (32 ~ 140ºF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
