Form Factor |
Mini-ITX Motherboard (170 x 170 mm) |
CPU |
Intel® Atom N270 ( 1.6 GHz ) @ 533 MHz FSB |
Memory |
1 x DDR2 SO DIMM support 400/533 MHz up to 2.0 GB |
Chipset |
Intel® 945GSE & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel® 945GSE integrated GMA 950 Technology |
| LVDS Interface |
18-bit dual channel LVDS interface |
| DVI/LVDS Interface |
Optional DVI or secondary 18/24-bit dual channel LVDS interface |
Serial ATA Interface |
2 x Serial ATA Interface with 150 MB/s transfer rate. |
| PCI Enhanced IDE |
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices |
| Solid State Disk |
IDE supports 44-pin DiskOnModule +5V power supply
1 x CompactFlash Type II socket. |
Audio Interface |
Intel ICH7M integrated with Realtek ALC888 7.1CH HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI Express Mini card & 1 x Min-PCI socket,
1 x PCI slot |
External I/O Port |
1 x PS/2 Keyboard / Mouse , 2 x RJ45 LAN , 6 x USB , 1 x VGA , 1 x COM , 1 x Audio , 1 x SPDIF |
| Internal I/O Port |
1 x RS232/422/485 & 4 x RS232 , 1 x IrDA , 2 x USB 2.0 ,
1 x 8-bit GPIO , 1 x Audio , 1 x CDIN , LVDS and LCD
inverter connector, 1 x HDTV |
Power Requirement |
Standard ATX power supply |
| Board Dimension |
170mm x 170mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
