Form Factor |
Half-size PCI bus CPU card (185 x 122 mm) |
CPU |
Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB |
Memory |
2 x DDR3 SO-DIMM 800/1066 MHz up to 4.0 GB |
Chipset |
Intel® GM45 & ICH9M express chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
VGA Interface |
Intel® GM45 integrated GMA X4500 Technology |
| LVDS Interface |
24-bit dual channel LVDS interface |
| DVI Interface |
1 x DVI-I interface |
Serial ATA Interface |
4 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
ICH9-M integrated with Realtek HD Audio codec |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
Min-PCI and PCI Express Mini card socket |
External I/O Port |
2 x RJ45 LAN ports, 1 x DVI-I port,1 x PS/2 Keyboard / Mouse ports |
| Internal I/O Port |
1 x RS232/422/485 & 1 x RS232, 1 x SMBUS, 1 x IrDA,
8 x USB 2.0, 1 x 8-bit GPIO, 1 x HD Audio, 1 x CDIN,
LVDS and LCD inverter connector, 1 x HDTV |
Power Requirement |
DC 5V/12V power required, optional 5VSB for ATX mode
Onboard 4-pin power connector & 3-pin ATX connector |
| Board Dimension |
185 x 122 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
