WIZ810MJ |
WIZ811MJ |
WIZ812MJ |
Architecture |
TCP/IP |
W5100 |
PHY |
Embedded in W5100 |
Mag Jack |
RDA-125BAG1A |
Interface |
10/100 Base-T Ethernet (Auto Detection) |
Network |
Protocol |
TCP, UDP, IP, ARP, ICMP, IGMP, PPPoE, MAC |
Dimension(mm) |
52 x 25 x 21 (W x H x D) |
55.5 x 25 x 23.5 (W x H x D) |
Connector Type |
2mm pitch 14 x 2 header |
2.54mm pitch 10 x 2 header |
J2:9 GND ->RX_LED
J2:10 GND ->TX_LED
J2:19 GND ->LINK_LED |
PCB Through Hole |
X |
Two PCB Throughhole (ø3.00mm) |
Four PCB Throughhole (ø3.00mm) |
SPI Signal Pin |
Shared for SPI and BUS signals |
Separated for SPI signals (SPI_EN controlled by /SCS signal) |
LINK LED |
When the link is established, LED is on and flashes at the TX or RX |
When the link is established, LED is on, but not flashes at the TX or RX |
Input Voltage |
3.3V internal operation and 5V tolerant I/Os |
Power Consumtion |
10/100 baseT max. 185mA (3.3V) |
