²úÆ·Ãû³Æ£º
²©¿Ø ÍøÂçÄ£¿éWIZ200WEB
ÐÍ ºÅ£º
WIZ200WEB
ÌØÕ÷ |
- »ùÓÚW5300¿ª·¢µÄ - ǶÈëʽHTTP·þÎñÆ÷ - Ö§³ÖTCP¡¢UDP¡¢HTTP¡¢HDCPµÈ - ¼òµ¥Ò×ÓõÄÅäÖù¤¾ß - 10/100Mbps×ÔÊÊÓ¦ÒÔÌ«Íø½Ó¿Ú - ¿ÉÔ¶³Ì²É¼¯Î¶ȡ¢Ñ¹Á¦¡¢Êª¶ÈµÈ - ·ûºÏRoHS±ê×¼ - ³ß´ç£º60 x 42 x 14 mm
¹æ¸ñ |
WIZ200WEB |
MCU |
Atmega128 |
RAM |
Internal 4Kbyte, External 32Kbyte |
| ROM |
Internal 128Kbyte, External 512Kbyte |
| LAN |
WIZnet W5300 Hardwired TCP/IP |
Power Consumption |
170mA |
WIZ200WEB-EVB |
Power |
DC 5V 500mA |
LED |
4 LED |
| SWITCH |
2 Slide Switch |
| Temperature Sensor |
TC77 -55¡ãC~+125¡ãC |
| VR |
10k VARIABLE RESISTOR |
| JTAG I/F |
2x10 male 2.54mm pin header |
| ISP I/F |
2x3 male 2.54mm pin header (MKII ISP) |
| Serial I/F |
UART0 & 1, RS232 Serial Port |
| LAN Port |
RJ45 with Transformer (1CT:1CT), 2LED |
¶©»õÐÅÏ¢ |
| Model |
Description |
| WIZ200WEB |
Embedded Web Server Module |
| WIZ200WEB-EVB |
Evaluation Board for WIZ200WEB | | |
parent.Resize_Frame('main_content');
