ÌØÕ÷ |
- ´®¿ÚתÒÔÌ«ÍøÉ豸 - »ùÓÚW5100 - ´®¿ÚËÙÂʿɴï230Kbps - Ö§³ÖPPPoE - Ö§³ÖÃÜÂëÉèÖà - 10/100Mbps×ÔÊÊÓ¦ÒÔÌ«Íø½Ó¿Ú - ¼òµ¥Ò×ÓõÄÅäÖù¤¾ß - ³ß´ç£º75 x 50 x 17 mm
¹æ¸ñ |
Architecture |
TCP / IP |
W5100 |
PHY |
Included in W5100 |
| Serial |
RS-232 |
| MCU |
GC89L591A0-MQ44I(fast 80C52 compatible) - 62K Bytes in-system programmable(ISP) flash |
Network |
Interface |
10/100 Mbps auto sensing RJ-45 Connector |
Protocol |
TCP, UDP, IP, ARP, ICMP, MAC, PPPoE |
| Serial |
Signals |
TXD, RXD, RTS, CTS, GND |
| Parameters |
Parity : None, Even, Odd Data bits : 7,8 Flow Control : RTS/CTS, XON/XOFF |
| Speed |
Up to 230Kbps |
| Dimensions |
75mm X 45mm (PCB width X length) |
Input Voltage |
5V Adoptor |
Power Consumption |
DC 5V, Under 180mA |
Temperature |
0¡æ ~ 80¡æ (Operating) -40¡æ ~ 85¡æ (Storage) |
Humidity |
10 ~ 90% |
