²úÆ·Ãû³Æ£º
²©¿Ø ÆÀ¹À°åW5300E01-ARM
ÐÍ ºÅ£º
W5300E01-ARM
ÌØÕ÷ |
- ʹÓÃW5300 - ³¬¹ý50MbpsµÄÊý¾Ý´«Êä - Ö§³Ö¶àÖÖ½Ó¿Ú£º´®¿Ú¡¢ÒÔÌ«Íø¡¢USB - ²Ù×÷ϵͳ£º Linux²Ù×÷ϵͳ - 64MµÄ´æ´¢
¹æ¸ñ |
Item |
Category |
Description |
W5300E01-ARM Base Boar |
MCU |
200MHz Samsung S3C2410A ARM RISC Processor |
| RAM |
SDRAM 64MB |
| ROM |
NAND Flash 64MB |
Serial |
RS-232C 1 Port |
USB Host |
USB Host 1port |
Ethernet |
WIZ830MJ Module |
| LCD |
16 Character * 2 Line Character LCD Port (C-LCD Option |
| LED |
2 LEDs for Debugging |
| Button |
2 Tact Switches for Debugging |
| JTAG |
On board JTAG Connector |
| Module Connector |
56 Pin (28Pin * 2) 2.54 mm Pitch Pin-Header Socket |
Extension Port |
120 Pin (40pin * 3) 2.54 mm Pitch Pin-Header Port |
| Power |
DC 5V / 2A Adapter |
| PCB |
118mm X 97mm Size |
WIZ830MJ |
TCP/IP |
W5300 |
| RJ-45 |
