iStorage Module
MCU |
AVR 8bit RISC CPU (AT90USB1287) |
RAM |
8Kbytes internal RAM |
| ROM |
128Kbytes Flash program memory (AVR Internal Flash) |
| CLOCK |
16MHz Crystal |
| LAN |
W5100 |
| USB |
USB2.0 (Full Speed) / USB OTG |
Power Consumption |
175mA |
iStorage Base Board
Power |
DC 5V Input |
LED |
4 Chip LED |
| SWITCH |
5 Direction Joystick Switch |
| JTAG I/F |
2 x 10 male 2.54 mm pin header |
| ISP I/F |
2 x 3 male 2.54 mm pin header (MKII) |
| SERIAL I/F |
RS232 Serial Port |
| USB |
USB Mini (Device) and USB Type A (Host) |
| LAN Port |
RJ45 with Transformer (1CT:1CT), 2LED |
