Form Factor |
Half-size PISA CPU Card |
CPU |
Mobile Intel® Core8482;2 Duo with Socket P @ 677/800/1066MHz FSB. |
Memory |
2 x 204-pin DDR3 800/1066MHz SDRAM up to 4 GB |
Chipset |
Intel GM45 and ICH9M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
VGA Interface |
Intel integrated extreme GMA 4500MHD (Graphic Media Accelerator) Technology |
LVDS Interface |
Onboard 18/24-bit dual channel LVDS connector |
DVI Interface |
Onboard DVI transmitter with 26-pin DVI connector |
Serial ATA Interface |
3 x serial ATAII interface with 300MB/s transfer rate. |
Audio Interface |
Intel integrated ICH9-M with Realtek HD Audio. |
LAN Interface |
2 x Intel 82574L Gigabit Ethernet controllers. |
GPIO Interface |
Onboard programmable 8-bit Digital I/O interface. |
Extend Interface |
1 x PCI Express Mini Card socket |
External I/O Port |
2 x RJ45 LAN port, 1 x DB15 VGA port, 1 x PS/2 Keyboard/Mouse Port
(For HS-873PXG2, HS-873PXDG2 only) |
1 x RJ45 LAN port, 1 x DB15 VGA port, 1 x PS/2 Keyboard/Mouse Port,1 x DB9 RS232
(For HS-873PXG, HS-873PXDG only) |
Internal I/O Port |
1 x RS232, 1 x RS232/422/485, 1 x FDD, 1 x GPIO,
1 x LPT, 1 x CDIN connector, 6 x USB,
1 x Audio connector, 1 x LVDS, 1 x HDTV,
1 x IrDA connector, 1 x Onboard 5-pin AT keyboard Port,
1 x 5-pin LCD inverter connect,
1 x DVI (For HS-873PXDG, HS-873PXDG2 only) |
Power Requirement |
DC 5V/12V power required, optional 5VSB for ATX
Onboard 4-pin power connector & 3-pin ATX connector |
Board Dimension |
185 mm x 127 mm (L x W) |
Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
