²úÆ·Ãû³Æ£º CMB-374
ÐÍ ºÅ£º CMB-374
Æ· ÅÆ£º 735
Form Factor Fanless barebone system
3.5" Board   Inside Motherboard can be :
 LE-374          :LE-374 with onboard Intel Atom N270(1.6GHz)
 LS-371U25    : LS-371 with onboard Intel U2500 CPU
 LE-370PM14 : LE-370 with onboard P-M 1.4 GHz CPU
 LE-370CM6   : LE-370 with onboard C-M 600 MHz CPU
 LE-365D        : LE-365D with onboard VIA Eden 1.0 GHz
 LE-365E5D    : LE-365E5D with onboard VIA Eden 500 MHz
Drive Bay  Internal 1 x 2.5" HDD
Riser card  No
Front Panel  System Reset switch
 Power On/Off
 HDD LED for activity
Mounting  Wall mounting / Desk
Rear Side I/O
 Depend on 3.5 SBC rear IO
Environment  Operating Temperature: 0 ~ 40C
Power supply  DC input for DC jack
Dimension  195 x 110 x 80 mm
Weight  Approx. 1.41 kg (Without HDD)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
