Form Factor |
PICMG 1.0 SBC |
CPU |
Support Intel Penryn Processor
Package type: Micro-FCPGA478 (Socket P)
Front Side Bus: 667/800/1066MHz |
Memory |
2 x 204-pin SO-DIMM DDR3 800/1066MHz up to 4 GB |
Chipset |
Intel® GM45 & ICH9M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
System Reset Time-out Counter ranges from 1sec (min) to 255sec (min) |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
VGA Interface |
Mobile Intel® Graphics Media Accelerator (GMA) 4500MHD |
Video Memory |
Up to 1024 MB shared with system memory |
LVDS Interface |
Onboard 18/24-bit Dual channel LVDS connector with +3.3V/+5V/+12V power supply |
DVI Interface |
Onboard DVI transmitter with 26-pin DVI connector (optional) |
Serial ATA Interface |
3 x SATAII @ 300MB/s interface speed
2 x SATAI @ 150MB/s interface speed (support RAID 0, 1) |
IDE Interface |
1 x 40-pin UltraATA133 for 2 compatible devices |
Solid State Disk |
1 x Compact Flash Type II interface |
Audio Interface |
Intel integrated ICH9-M with Realtek HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet controllers (optional) |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
2 x PCI Express Mini Card (optional)
1 x Compact Flash socket
1 x Mini PCI socket Type IIIA (optional) |
Internal I/O Port |
1 x RS232/422/485, 1 x RS232 (optional), 1 x SMBUS,
1 x GPIO, 1 x HDTV, 8 x USB, 1 x IrDA, 1 x LVDS,
1 x LCD inverter, 1 x AT keyboard, 5 x SATA, 1 x IDE,
1 x LPT, 1 x FDD, 1 x Front Panel Audio, 1 x CDIN,
1 x DVI (optional) |
External I/O Port |
RS232, LAN, VGA, PS/2 keyboard & Mouse
(For FS-97EXG, FS-97EXDG only) |
2 x LAN, VGA, PS/2 keyboard & Mouse
(For FS-97EXG2, FS-97EXDG2 only) |
Power Requirement |
+5V, +12V & 5VSB |
Board Dimension |
338mm x 122 mm |
Operation Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
