²úÆ·Ãû³Æ£º
×îС¸É»É¹ÜWB-003DT
ÐÍ ºÅ£º
WB-003DT
Part No. |
ÐͺŠ|
WB-003DT |
Total Length |
×ܳ¤¶È |
26.5mm |
Glass Length |
²£Á§³¤¶È |
5 mm |
Glass Diameter |
Ö±¾¶ |
1.4mm |
Contact Form |
´¥µãÐÎʽ |
1A £¨ SPST-NO £© |
Contact Position |
´¥µãλÖà |
SYM |
Contact Material |
´¥µã²ÄÖÊ |
Ru |
Contact Rating |
´¥µã¸ºÔØ |
1W |
Max. Switching Voltage |
×î´ó¿ª¹Øµçѹ |
30 VDC / VAC |
Max. Switching Current |
×î´ó¿ª¹ØµçÁ÷ |
0.5A |
Contact Resistance (at initial value) |
½Ó´¥µç×è ( ³õʼֵ ) |
700 mOhms |
Pull In Value (AT) |
Æô¶¯Öµ |
5-20 |
Drop Out Value (AT) |
ÊÍ·ÅÖµ |
4 |
Operation Time |
¶¯×÷ʱ¼ä |
0.5 mSec.(Max.) |
Release Time |
ÊÍ·Åʱ¼ä |
0.3 mSec.(Max.) |
Breakdown Voltage |
Ä͸ßѹ |
150 VDC |
Contact Capacitance |
´¥µãµçÈÝ |
0.5 pF |
Insulation Resistance |
¾øÔµµç×è |
109Ohms |
Resonant Frequency |
гÕñƵÂÊ |
700Hz |
Operation Temperature |
¹¤×÷ζȷ¶Î§ |
-40 ¡æ ~+125 ¡æ |
High Humidity |
×î¸ßʪ¶È |
98% (Max.) |
Operation Frequency |
×î¸ß¹¤×÷ƵÂÊ |
400 Hz |
Electrical Life |
µçÆøÊÙÃü |
5¡Á106£¨50mV£¬5¦ÌA£© 5¡Á106£¨5V£¬10mA£© 1¡Á105£¨24V£¬250mA£© |
Test Coil |
²âÊÔÏßȦ |
5000 ¡¡580 Ohm |
Leads |
ÒýÏ߽Š|
