µÂ¹ú¿â²®ÀÕKUBLER±àÂëÆ÷ KUBLERÐýת±àÂëÆ÷ KUBLER¹âµç±àÂëÆ÷ KUBLER´ÅÐÔ±àÂëÆ÷ KUBLERÀÉþ±àÂëÆ÷ KUBLERÔöÁ¿ÐͱàÂëÆ÷ KUBLER¾ø¶ÔÖµÐͱàÂëÆ÷ KUBLERÀÏߺРKUBLER´ÅÐÔϵͳ KUBLERÏÔʾÒDZí KUBLERÔ¤ÉèÖÃÒDZí KUBLERʱ¼ä±í KUBLER¼ÆÊ±Æ÷ KUBLER¼ÆÊýÆ÷ KUBLERÔ¤Éèʱ¼äÆ÷ KUBLERʱ¼ä¼ÌµçÆ÷ KUBLERתËÙ¼Æ KUBLERλÖÃָʾÆ÷ KUBLER¹âµç´«¸ÐÆ÷ KUBLER²â¾à¹âµç´«¸ÐÆ÷ KUBLER¹âÕ¤ KUBLER¹âÄ» KUBLER¹âÏË´«¸ÐÆ÷ KUBLERÑÕÉ«´«¸ÐÆ÷ KUBLERÉ«±ê´«¸ÐÆ÷ KUBLERÊÓ¾õ´«¸ÐÆ÷
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÔöÁ¿ÐͱàÂëÆ÷
KUBLER (KUEBLER)5020ϵÁÐ SENDIXÐÍ£¬°²È«Ëø¿ÛÉè¼Æ£¬12000RPM,Öá¾¶6¡15.7£¬KUBLER (KUEBLER)5822ϵÁÐ Ö±¾¶58£¬±ê×¼Ðͺţ¬6000RPM,Öá¾¶10¡12£¬KUBLER (KUEBLER)5820ϵÁÐ 58MM¹¤Òµ±ê×¼£¬12000RPM,Öá¾¶10¡12£¬PURµçÀ£¬KUBLER (KUEBLER) 5820MϵÁУ¬³ÝÂֵ綯»ú±àÂëÆ÷£¬×îÓÅ»¯×î¼ÑµÄÁ¬½Ó£¬12000RPM,Öá¾¶6¡15£¬5000¡36000PPR, KUBLER (KUEBLER) 5823ϵÁÐ ¸ßÎÂÐÍ£¬110¡æ£¬TPEµçÀ£¬Öá¾¶6¡12£¬KUBLER (KUEBLER)5824ϵÁÐ ÕýÏÒ²¨Êä³öÐÍ£¬×î¸ß8룬12000RPM,Öá¾¶6¡15£¬KUBLER (KUEBLER) 5825ϵÁÐ ¸ß·Ö±æÐÍ£¬36000PPR,800KHZ,Öá¾¶6¡15£¬KUBLER (KUEBLER)5826ϵÁÐ ²»Ðâ¸ÖÐÍ£¬Íâ¿ÇºÍÖáÌ×Ϊ²»Ðâ¸ÖÖÆ£¬·Ç³£ÊʺÏʳƷºÍ°ü×°ÐÐÒµ£¬12000RPM,Öá¾¶10¡12
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÔöÁ¿ÐͱàÂëÆ÷¸ß´ï ?42 mmµÄÖáÌ×ÐÍ
KUBLER (KUEBLER) A020ϵÁÐ ÖеȸººÉÐÍ£¬Öá¾¶19¡42£¬KUBLER (KUEBLER) A02HϵÁÐÖØÔØÐÍ£¬²»Ðâ¸ÖÖÆÁªÖáÆ÷£¬·ÀÕð·À³å»÷ÐÔÄܺ㬿ÉÑ¡¾øÔµÄڳģ¬ÒÔ¼õÉÙÖáµçÁ÷ºÍÔëÉù¶Ô±àÂëÆ÷¸ÉÈÅ£¬ÓÈÆäÊÊÓÃÓÚACʸÁ¿µç»ú£¬Íâ¿Ç100MM,6000RPM,Öá¾¶19¡42, KUBLER (KUEBLER)0320ϵÁÐ ³öÏàÐÍ£¬Íâ¿Ç103MM,Öá¾¶12¡25.4 1``
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)²»Ðâ¸ÖÖÆÔöÁ¿ÐͱàÂëÆ÷
KUBLER (KUEBLER) 9000ϵÁÐ ÖáºÍÍâ¿ÇÓɲ»Ðâ¸ÖÖÆ£¬Ôö¼ÓÁËÖáÏòºÍ¾¶Ïò¸ººÉÖµ140N,IP66·À»¤£¬ÊÊÓÃÓÚʳƷºÍ°ü×°ÐÐÒµ£¬Íâ¾¶90MM,Öá¾¶12MM,6000RPM
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÔöÁ¿ÐͱàÂëÆ÷ ATEX·À±¬ÐÍ ÊÊÓÃÓÚ2ÇøºÍ22Çø
KUBLER (KUEBLER) 7030ϵÁÐ ½ô´ÕÖáÐÍ ·À»ðÈÏÖ¤£¬ATEXÈÏÖ¤£¬·À³¾ÈÏÖ¤£¬ÊÊÓÃÓÚ1Çø£¬2Çø£¬21ÇøºÍ22Çø£¬ExII2GEExdIICT6 and ExII2DIP6xT85¡ãC£¬¶Ì·±£»¤Êä³ö£¬·´ÏàÐźű£»¤ÊäÈ룬¹ýµçѹ±£»¤£¬6000RPM,Öá¾¶12MM
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER) µ¥È¦¾ø¶ÔÖµ±àÂëÆ÷ ÖáÐÍ
KUBLER (KUEBLER) 3650ϵÁÐ ´ÅÐÔµ¥È¦±àÂëÆ÷ ÊÊÓÃÓÚ¶ñÁÓ»·¾³ °²È«Ëø¿ÛÉè¼Æ ²âÁ¿·¶Î§45¡ã,90¡ã,180¡ã£¬360¡ã£¬6000RPM,Öá¾¶6£¬9BIT, KUBLER (KUEBLER) 5853ϵÁÐ SENDIX °²È«Ëø¿ÛÉè¼Æ£¬10MHZʱÖÓÆµÂÊ£¬LED״ָ̬ʾ£¬12000RPM,Öá¾¶6¡¢10£¬17BIT, KUBLER (KUEBLER) 5850ϵÁÐͨÓÃÐ͵¥È¦±àÂëÆ÷£¬12000RPM,Öá¾¶6¡¢10£¬14BIT, KUBLER (KUEBLER)5852ϵÁÐΪ5850ϵÁеĴ®Ðнӿڰ棬KUBLER (KUEBLER) 5858ϵÁÐSENDIX °²È«Ëø¿ÛÉè¼Æ£¬¿ÉÖ§³ÖPROFIBUS-DP,CANOPEN,ETHERCATµÈÏÖ³¡×ÜÏߣ¬9000RPM,Öá¾¶6¡¢10£¬16BIT, KUBLER (KUEBLER) 7031ϵÁУ¬½ô´ÕÖáÐÍ£¬´øÓзÀ»ðÈÏÖ¤ ATEXÈÏÖ¤£¬·À³¾ÈÏÖ¤£¬6000RPM,Öá¾¶12£¬14BIT
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÖáÌ×Ð͵¥È¦¾ø¶ÔÖµÐͱàÂëÆ÷
KUBLER (KUEBLER) 3670ϵÁÐ ´ÅÐÔµ¥È¦ °²È«Ëø¿ÛÉè¼Æ£¬6000RPM£¬Öá¾¶6¡10£¬9BIT, KUBLER (KUEBLER) SENDIX °²È«Ëø¿ÛÉè¼Æ£¬20MHZ,LEDָʾ£¬9000RPM,Öá¾¶10¡15£¬17BIT, KUBLER (KUEBLER) 5870ϵÁÐÖáÌ×ÐÍͨÓõ¥È¦±àÂëÆ÷£¬6000RPMÖá¾¶10¡12£¬14BIT, KUBLER (KUEBLER)5872ϵÁÐΪ5850ϵÁв¢Ðнӿڰ棬KUBLER (KUEBLER)5878ϵÁУ¬SENDIX °²È«Ëø¿ÛÉè¼Æ£¬¿ÉÖ§³ÖPROFIBUS-DP,CANOPEN,ETHERCATµÈÏÖ³¡×ÜÏߣ¬9000RPM,Öá¾¶10¡15£¬16BIT, KUBLER (KUEBLER)5876ϵÁв»Ðâ¸ÖÐÍ£¬ÊÊÓÃÓÚʳƷ¼°°ü×°ÐÐÒµ£¬6000RPM,Öá¾¶12£¬14BIT
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÖáÐͶàȦ¾ø¶ÔÖµÐͱàÂëÆ÷
KUBLER (KUEBLER)5863ϵÁÐ SENDIX£¬¼á¹ÌµÄÖá³Ð»úе½á¹¹£¬´øÓо¯¸æºÍÔ¤Öª¹¦ÄÜ£¬¸ß¶È¼¯³ÉµÄµç×Ó»ú¹¹£¬100KHZ,LED״̬µÆ£¬12000RPM,Öá¾¶6¡10£¬29BIT, KUBLER (KUEBLER)5862SϵÁÐ ×î¾ß¼Û¸ñÓÅÊÆµÄ¶àȦÐÍ£¬ÉèÖúÍF/RÊäÈ룬±¨¾¯Êä³ö£¬6000RPM,Öá¾¶6¡10£¬25BIT, KUBLER (KUEBLER)5862ϵÁУ¬Í¨ÓÃÐÍ£¬¿É±à³Ì£¬ËĸöÊä³ö£¬6000RPMÖá¾¶6..10£¬25BIT, KUBLER (KUEBLER)5860ϵÁУ¬Ã¤¿×ÖáÌ×ÐÍ»òÖáÐÍ£¬Ö§³ÖPROFIBUS-DP,CANOPEN,DEVICENET,6000RPM,ÖáÐÍÖá¾¶6¡10£¬Ã¤¿×ÖáÌ×ÐÍ10¡15£¬25BIT, KUBLER (KUEBLER)5868ϵÁУ¬SENDIXÉè¼Æ£¬Ö§³ÖPROFIBUS-DP,CANOPEN,CANLIFT,ETHERCAT,9000RPM,Öá¾¶6¡10£¬28BIT
µÂ¹ú¿â²®ÀÕKUBLER (KUEBLER)ÖáÌ×Ð;ø¶ÔÖµ¶àȦ±àÂëÆ÷
KUBLER (KUEBLER)5883ϵÁУ¬SENDIXÉè¼Æ£¬100KHZ,9000RPM,Öá¾¶10¡15£¬29BIT, KUBLER (KUEBLER)5882SϵÁÐ ×î¾ß¼Û¸ñÓÅÊÆµÄ¶àȦÐÍ 6000RPM,Öá¾¶10¡12£¬25BIT, KUBLER (KUEBLER)5882ϵÁÐͨÓÃÐÍ£¬¿É±à³Ì£¬6000RPM,Öá¾¶10¡12£¬25BIT, KUBLER (KUEBLER)5860ϵÁУ¬Ã¤¿×ÖáÌ×ÐÍ»òÖáÐÍ£¬Ö§³ÖPROFIBUS-DP 2.0,6000RPM,ÖáÐÍ6¡10£¬Ã¤¿×ÖáÌ×ÐÍ10¡15£¬25BIT, KUBLER (KUEBLER)5888ϵÁУ¬×ÜÏßʽ£¬Ö§³ÖPROFIBUS-DP,CANOPEN,CANLIFT,ETHERCAT,9000RPM,Öá¾¶10¡15£¬28BIT, KUBLER (KUEBLER)9081ϵÁУ¬ËÄÖֿɱà³ÌÊä³ö£¬6000RPM,Öá¾¶12¡28£¬25BIT, KUBLER (KUEBLER)9080ϵÁУ¬×ÜÏßʽ´óÖáÌ×ÐÍ£¬Ö§³ÖPROFIBUS-DP,CANOPEM,DEVICENET,6000RPM,Öá¾¶12¡25£¬25BIT
ÐͺÅÈ磺D5.2501.2421.1000£¬ D5.2501.2441.1000£¬D5.3501.A111.0000£¬D5.3501.A221.0000£¬D5.3501.A331.0000£¬D5.3502.A111.0000£¬D5.3502.A221.0000£¬D5.3502.A331.0000£¬D8.1106.0243.2000£¬D8.1106.0283.2000£¬D8.12A1.0243.2000£¬D8.12A1.0283.2000£¬05.2400.0040.1000.5045£¬8.0010.4021£¬8.0010.4022£¬8.0010.4023£¬8.0010.4024£¬8.0010.4025£¬8.0010.4026£¬8.0010.40V0.0000,8.0010.4T00.0000,8.0010.40S0,8.001040T0.000,8.001040U0.000,SENDIX 8.5873.XXXE.XXXX,SENDIX 8.5883.XXXE.XXXX,IS40 ¡À10¡ã, ¡À45¡ã , ¡À60¡ã,CODIX 54X,55X,57X,G 300 005,LIMES LI20,RI20,8.RI20.031.XXXX.111,8.RI20.041.XXXX.111,8.RI20.045.XXXX.111,8.LI20.1111.2005, 8.LI20.1111.2016, 8.LI20.1111.2020, 8.LI20.1111.2050, 8.LI20.1121.2005, 8.LI20.1121.2016, 8.LI20.1121.2020, 8.LI20.1121.2050,8.RI20.031.0800.111, 8.RI20.031.1000.111, 8.RI20.031.1200.111, 8.RI20.031.1500.111,8.RI20.1587.111,8.RI20.031.2000.111,6.572.0116.D05,6.572.0116.D958.8.3651.2322.1311, 8.3651.2322.1321, 8.3651.2322.1411, 8.3651.2322.1421, 8.3651.2322.2311, 8.3651.2322.2321, 8.3651.2322.2411, 8.3651.2322.2421, 8.3651.2322.3311, 8.3651.2322.3321, 8.3651.2322.3411, 8.3651.2322.3421, 8.3651.2322.4311,8.3651.2322.4321,8.3651.2322.4411,8.3651.2322.4421,8.3651.2324.1311, 8.3651.2324.1321, 8.3651.2324.1411, 8.3651.2324.1421, 8.3651.2324.2311, 8.3651.2324.2321, 8.3651.2324.2411, 8.3651.2324.2421, 8.3651.2324.3311, 8.3651.2324.3321, 8.3651.2324.3411, 8.3651.2324.3421, 8.3651.2324.4311, 8.3651.2324.4321, 8.3651.2324.4411, 8.3651.2324.4421,
8.3651.2332.1311, 8.3651.2332.1321, 8.3651.2332.1411, 8.3651.2332.1421, 8.3651.2332.2311, 8.3651.2332.2321, 8.3651.2332.2411, 8.3651.2332.2421, 8.3651.2332.3311, 8.3651.2332.3321, 8.3651.2332.3411, 8.3651.2332.3421, 8.3651.2332.4311,8.3651.2332.4321,8.3651.2332.4411,8.3651.2332.4421,8.3651.2334.1311, 8.3651.2334.1321, 8.3651.2334.1411, 8.3651.2334.1421, 8.3651.2334.2311, 8.3651.2334.2321, 8.3651.2334.2411, 8.3651.2334.2421, 8.3651.2334.3311, 8.3651.2334.3321, 8.3651.2334.3411, 8.3651.2334.3421, 8.3651.2334.4311, 8.3651.2334.4321, 8.3651.2334.4411, 8.3651.2334.4421,
8.3651.2342.1311, 8.3651.2342.1321, 8.3651.2342.1411, 8.3651.2342.1421, 8.3651.2342.2311, 8.3651.2342.2321, 8.3651.2342.2411, 8.3651.2342.2421, 8.3651.2342.3311, 8.3651.2342.3321, 8.3651.2342.3411, 8.3651.2342.3421, 8.3651.2342.4311,8.3651.2342.4321,8.3651.2342.4411,8.3651.2342.4421,8.3651.2344.1311, 8.3651.2344.1321, 8.3651.2344.1411, 8.3651.2344.1421, 8.3651.2344.2311, 8.3651.2344.2321, 8.3651.2344.2411, 8.3651.2344.2421, 8.3651.2344.3311, 8.3651.2344.3321, 8.3651.2344.3411, 8.3651.2344.3421, 8.3651.2344.4311, 8.3651.2344.4321, 8.3651.2344.4411, 8.3651.2344.4421,
8.3651.2522.1311, 8.3651.2522.1321, 8.3651.2522.1411, 8.3651.2522.1421, 8.3651.2522.2311, 8.3651.2522.2321, 8.3651.2522.2411, 8.3651.2522.2421, 8.3651.2522.3311, 8.3651.2522.3321, 8.3651.2522.3411, 8.3651.2522.3421, 8.3651.2522.4311,8.3651.2522.4321,8.3651.2522.4411,8.3651.2522.4421,8.3651.2524.1311, 8.3651.2524.1321, 8.3651.2524.1411, 8.3651.2524.1421, 8.3651.2524.2311, 8.3651.2524.2321, 8.3651.2524.2411, 8.3651.2524.2421, 8.3651.2524.3311, 8.3651.2524.3321, 8.3651.2524.3411, 8.3651.2524.3421, 8.3651.2524.4311, 8.3651.2524.4321, 8.3651.2524.4411, 8.3651.2524.4421,
8.3651.2532.1311, 8.3651.2532.1321, 8.3651.2532.1411, 8.3651.2532.1421, 8.3651.2532.2311, 8.3651.2532.2321, 8.3651.2532.2411, 8.3651.2532.2421, 8.3651.2532.3311, 8.3651.2532.3321, 8.3651.2532.3411, 8.3651.2532.3421, 8.3651.2532.4311,8.3651.2532.4321,8.3651.2532.4411,8.3651.2532.4421,8.3651.2534.1311, 8.3651.2534.1321, 8.3651.2534.1411, 8.3651.2534.1421, 8.3651.2534.2311, 8.3651.2534.2321, 8.3651.2534.2411, 8.3651.2534.2421, 8.3651.2534.3311, 8.3651.2534.3321, 8.3651.2534.3411, 8.3651.2534.3421, 8.3651.2534.4311, 8.3651.2534.4321, 8.3651.2534.4411, 8.3651.2534.4421,
8.3651.2542.1311, 8.3651.2542.1321, 8.3651.2542.1411, 8.3651.2542.1421, 8.3651.2542.2311, 8.3651.2542.2321, 8.3651.2542.2411, 8.3651.2542.2421, 8.3651.2542.3311, 8.3651.2542.3321, 8.3651.2542.3411, 8.3651.2542.3421, 8.3651.2542.4311,8.3651.2542.4321,8.3651.2542.4411,8.3651.2542.4421,8.3651.2544.1311, 8.3651.2544.1321, 8.3651.2544.1411, 8.3651.2544.1421, 8.3651.2544.2311, 8.3651.2544.2321, 8.3651.2544.2411, 8.3651.2544.2421, 8.3651.2544.3311, 8.3651.2544.3321, 8.3651.2544.3411, 8.3651.2544.3421, 8.3651.2544.4311, 8.3651.2544.4321, 8.3651.2544.4411, 8.3651.2544.4421,
8.3651.2622.1311, 8.3651.2622.1321, 8.3651.2622.1411, 8.3651.2622.1421, 8.3651.2622.2311, 8.3651.2622.2321, 8.3651.2622.2411, 8.3651.2622.2421, 8.3651.2622.3311, 8.3651.2622.3321, 8.3651.2622.3411, 8.3651.2622.3421, 8.3651.2622.4311,8.3651.2622.4321,8.3651.2622.4411,8.3651.2622.4421,8.3651.2624.1311, 8.3651.2624.1321, 8.3651.2624.1411, 8.3651.2624.1421, 8.3651.2624.2311, 8.3651.2624.2321, 8.3651.2624.2411, 8.3651.2624.2421, 8.3651.2624.3311, 8.3651.2624.3321, 8.3651.2624.3411, 8.3651.2624.3421, 8.3651.2624.4311, 8.3651.2624.4321, 8.3651.2624.4411, 8.3651.2624.4421,
8.3651.2632.1311, 8.3651.2632.1321, 8.3651.2632.1411, 8.3651.2632.1421, 8.3651.2632.2311, 8.3651.2632.2321, 8.3651.2632.2411, 8.3651.2632.2421, 8.3651.2632.3311, 8.3651.2632.3321, 8.3651.2632.3411, 8.3651.2632.3421, 8.3651.2632.4311,8.3651.2632.4321,8.3651.2632.4411,8.3651.2632.4421,8.3651.2634.1311, 8.3651.2634.1321, 8.3651.2634.1411, 8.3651.2634.1421, 8.3651.2634.2311, 8.3651.2634.2321, 8.3651.2634.2411, 8.3651.2634.2421, 8.3651.2634.3311, 8.3651.2634.3321, 8.3651.2634.3411, 8.3651.2634.3421, 8.3651.2634.4311, 8.3651.2634.4321, 8.3651.2634.4411, 8.3651.2634.4421,
8.3651.2642.1311, 8.3651.2642.1321, 8.3651.2642.1411, 8.3651.2642.1421, 8.3651.2642.2311, 8.3651.2642.2321, 8.3651.2642.2411, 8.3651.2642.2421, 8.3651.2642.3311, 8.3651.2642.3321, 8.3651.2642.3411, 8.3651.2642.3421, 8.3651.2642.4311,8.3651.2642.4321,8.3651.2642.4411,8.3651.2642.4421,8.3651.2644.1311, 8.3651.2644.1321, 8.3651.2644.1411, 8.3651.2644.1421, 8.3651.2644.2311, 8.3651.2644.2321, 8.3651.2644.2411, 8.3651.2644.2421, 8.3651.2644.3311, 8.3651.2644.3321, 8.3651.2644.3411, 8.3651.2644.3421, 8.3651.2644.4311, 8.3651.2644.4321,8.3651.2644.4411,8.3651.2644.4421,8.3671.2XXX.XXX1,8.3671.5XXX.XXX1,8.3658.23C2.2111
8.3658.23C4.2111,8.3658.25C2.2111,8.3658.25C4.2111,8.3658.26C2.2111,8.3658.26C4.2111,DS301 V4.02,DS305 V2.0,DS406 V3.1,8.3678.22C2.2111, 8.3678.22C4.2111, 8.3678.23C2.2111, 8.3678.23C4.2111, 8.3678.24C2.2111, 8.3678.24C4.2111, 8.3678.26C2.2111, 8.3678.26C4.2111,8.3678.52C2.2111, 8.3678.52C4.2111, 8.3678.53C2.2111, 8.3678.53C4.2111, 8.3678.54C2.2111, 8.3678.54C4.2111, 8.3678.56C2.2111, 8.3678.56C4.2111,8.5858.11B2.B112, 8.5858.12B2.B112, 8.5858.13B2.B112, 8.5858.14B2.B112, 8.5858.21B2.B112, 8.5858.22B2.B112, 8.5858.23B2.B112, 8.5858.24B2.B112, 8.5858.31B2.B112, 8.5858.32B2.B112, 8.5858.33B2.B112, 8.5858.34B2.B112, 8.5858.41B2.B112, 8.5858.42B2.B112, 8.5858.43B2.B112, 8.5858.44B2.B112, 8.5858.51B2.B112, 8.5858.52B2.B112, 8.5858.53B2.B112, 8.5858.54B2.B112, 8.5858.61B2.B112, 8.5858.62B2.B112, 8.5858.63B2.B112, 8.5858.64B2.B112, 8.5858.71B2.B112, 8.5858.72B2.B112, 8.5858.73B2.B112, 8.5858.74B2.B112,8.5878.13B2.B112, 8.5878.14B2.B112, 8.5878.15B2.B112, 8.5878.16B2.B112, 8.5878.18B2.B112, 8.5878.19B2.B112, 8.5878.23B2.B112, 8.5878.24B2.B112, 8.5878.25B2.B112, 8.5878.26B2.B112, 8.5878.28B2.B112, 8.5878.29B2.B112, 8.5878.33B2.B112, 8.5878.34B2.B112, 8.5878.35B2.B112, 8.5878.36B2.B112, 8.5878.38B2.B112, 8.5878.39B2.B112, 8.5878.43B2.B112, 8.5878.44B2.B112, 8.5878.45B2.B112, 8.5878.46B2.B112, 8.5878.48B2.B112, 8.5878.49B2.B112, 8.5878.53B2.B112, 8.5878.54B2.B112, 8.5878.55B2.B112, 8.5878.56B2.B112, 8.5878.58B2.B112, 8.5878.59B2.B112, 8.5878.63B2.B112, 8.5878.64B2.B112, 8.5878.65B2.B112, 8.5878.66B2.B112, 8.5878.68B2.B112, 8.5878.69B2.B112,8.5868.11B2.B112, 8.5868.12B2.B112, 8.5868.13B2.B112, 8.5868.14B2.B112, 8.5868.21B2.B112, 8.5868.22B2.B112, 8.5868.23B2.B112, 8.5868.24B2.B112, 8.5868.31B2.B112, 8.5868.32B2.B112, 8.5868.33B2.B112, 8.5868.34B2.B112, 8.5868.41B2.B112, 8.5868.42B2.B112, 8.5868.43B2.B112, 8.5868.44B2.B112, 8.5868.51B2.B112, 8.5868.52B2.B112, 8.5868.53B2.B112, 8.5868.54B2.B112, 8.5868.71B2.B112, 8.5868.72B2.B112, 8.5868.73B2.B112, 8.5868.74B2.B112,8.5888.13B2.B112, 8.5888.14B2.B112, 8.5888.15B2.B112, 8.5888.16B2.B112, 8.5888.18B2.B112, 8.5888.19B2.B112, 8.5888.23B2.B112, 8.5888.24B2.B112, 8.5888.25B2.B112, 8.5888.26B2.B112, 8.5888.28B2.B112, 8.5888.29B2.B112, 8.5888.33B2.B112, 8.5888.34B2.B112, 8.5888.35B2.B112, 8.5888.36B2.B112, 8.5888.38B2.B112, 8.5888.39B2.B112, 8.5888.43B2.B112, 8.5888.44B2.B112, 8.5888.45B2.B112, 8.5888.46B2.B112, 8.5888.48B2.B112, 8.5888.49B2.B112, 8.5888.53B2.B112, 8.5888.54B2.B112, 8.5888.55B2.B112, 8.5888.56B2.B112, 8.5888.58B2.B112, 8.5888.59B2.B112, 8.5888.63B2.B112, 8.5888.64B2.B112, 8.5888.65B2.B112, 8.5888.66B2.B112, 8.5888.68B2.B112, 8.5888.69B2.B112,8.B1.10.010.0010, 8.B1.10.010.0020, 8.B1.10.010.0040, 8.B1.10.010.0050, 8.B1.10.010.0060, 8.B1.10.010.0100, 8.B1.10.010.0200, 8.B2.10.010.0010, 8.B2.10.010.0020, 8.B2.10.010.0040, 8.B2.10.010.0050, 8.B2.10.010.0060, 8.B2.10.010.0100, 8.B2.10.010.0200,8.LI50.1111.2050,8.LI50.1111.2250,8.LI50.1121.2050,8.LI50.1121.2250,D8.6A1.0125.3642.1250, D8.6A1.0025.3641.0500, D8.6A1.0025.3642.0600, D8.6A1.0050.3641.0750, D8.6A1.0050.3642.1000,D8.3A1.0025.A111.0000, D8.3A1.0050
