Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú SAGLE SIGNAL¼ÆÊ±Æ÷
²úÆ·Ãû³Æ£º SAGLE SIGNAL¼ÆÊ±Æ÷
ÐÍ ºÅ£º DA211A6
The DA200 series timer is a microprocessor based repeat cycle timer
housed in a 1/8 DIN style enclosure. Two 4 digit push-button switches
on the front of the unit provide exact setting of the ON and OFF time
setpoints. Four time ranges from 99.99 seconds to 99 hours and 99
minutes can be independently programmed for the ON and OFF times.
Repeat or Single Cycle operation and ON or OFF time first operation
can also be programmed. All programming is done using rocker
switches located on the side of the unit.
The DA200 timer can be mounted in three ways for use in most any
application. The terminal connections for the unit are 3/16 inch
terminals for use with a square base relay socket. This provides a
means of mounting the unit within a panel. The DA200 timer can also
be mounted through the front of the panel using either an economical
fixed bezel kit or a unique plug-in housing which allows easy removal
for programming changes and replacement.
¹«Ë¾Ãû³Æ£º ÉϺ£»ãÏÍ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾
µç »°£º 021 32568091 / Íõ»ªÁá
ÊÖ»ú£º 13916551124
µØ Ö·£º ÉϺ£ÆÕÍÓÇø4703ºÅÀî×ÓÔ°´óÏÃ6ºÅÂ¥×ù1304ÊÒ
ÓÊ ±à£º 200363
Ö÷ Ò³£º http:www.automate-ace.com
  • WEST ¿ØÖÆÆ÷Íâ¹ú½ø¿Ú
  • ÓÅÄ῵¹ã·ºÓ¦ÓõÄplc
  • SETRA ²îѹ±äËÍÆ÷
  • UNITRONICS PLC
  • PARTLOW 1161+ÎÂ¿ØÆ÷
  • ÃÀ¹úESA´¥ÃþÆÁ
  • WEST¹ý³Ì¿ØÖÆÆ÷P6100
  • Unitronics jz10 ¼Û¸ñ
  • ÃÀ¹úBANNER´«¸ÐÆ÷
  • Hengstler ×î¹ã·ºÊ¹ÓõļÆÊýÆ÷
